What does this mean EXACTLY? I did a search and cant find the reason why.
Im converting an AVI. file to DVD and this happened once before and there was no apparently loss in quality, so I think its safe but it happens every so often, with the same file types. It does this all the way through the movie too (eg. frame 160, frame 221, frame 610, frame 650 etc, ) but it does it more frequently than that.
I'm at a loss as to exactly what yopu mean since ther is not enough info but I'm assuming what you are referring to is a the conversion from AVI to DVD compliant MPEG. AVI won't play on just about any standalone DVD player and the ones that do have to be in a compressed format such as DIVX.
Im converting using VSO Divx to DVD sorry. Im still a little green at this, I should have explained more. It converts the file into dvd format so I can watch it on my standalone dvd player.
COPIED OVER 600 DVDS SO FAR -
Originally Posted by mattyboy
I think you answered your own question.
Is there a way to transfer to computer from video camera beside .AVI
By sj022698 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Apr 2011, 09:06 -
Possible to transfer avi from Nikon Coolpix L19 w/o the Nikon utility?
By brassplyer in forum Capturing and VCRReplies: 2Last Post: 4th Jan 2011, 17:28 -
Can't transfer .avi file from camera...
By Captain Satellite in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 12:32 -
Transfer AVI files from Laptop to Desktop via firewire?
By manhnt in forum Newbie / General discussionsReplies: 11Last Post: 1st Aug 2008, 14:51 -
AVi files transfer(capture) does this sound right?
By caveman in forum Capturing and VCRReplies: 3Last Post: 25th Oct 2007, 21:18
