I want to burn a .avi to a DVD which I would be able to watch it on TV. Can someone tell me how to do that?
Unless you have an AVI settop player that will play DIVX or XVID format or you use a computer that outputs to a TV, you really can't.
To play a video on most DVD settop players, you have to convert to MPEG as in a DVD, or a VCD and sometimes a SVCD.
A DVD would require encoding the AVI to MPEG2 (Compliant to DVD standards), then authoring to DVD format.
A easy way would be a program like DIKO or TheFilmMachine, depending on what type of AVI you have.
For the best quality, you need a good MPEG encoder and an authoring program.
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 09:36 -
Avi burning problems
By blitzen in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2011, 12:09 -
Burning .avi to DVD
By monieeka in forum MacReplies: 6Last Post: 12th Sep 2008, 06:40 -
Burning .avi files
By pilgrim02 in forum MacReplies: 13Last Post: 31st Jul 2007, 11:52 -
AVI to DVD Burning
By DVDHelpPlease in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2007, 23:38
