I have tried everything and certain discs I have discs do not look good after compression...using a Mac....(DvdBackup > DVD2xone and Popcorn, burn with Toast).. I have read all the posts...
Someone suggested copy to 2 discs after ripping, splitting it up, no compression, how do I do that?
Do I need to use DVD2xone? Is there a way to dump certain files in Toast (I tried to do it and the first disc some chapters had no sound, etc.. )?
TIA
IAmNAP:Originally Posted by IAmNotAPirate
Thanks, but I am a Mac user, this will not work
Thanks -
Use DVD2OneX in Movie Only mode, select the title you want and the audio tracks desired, and in the right side drawer, in the "Cells/Chapters/Layers" tab, select Layers mode, and check one layer at a time and extract. Repeat for the other layer, and you now have two VIDEO_TS folders that can be burned to separate DVD-Rs.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
Possible to rip DVD to MP4 without compression?
By kashiko in forum DVD RippingReplies: 1Last Post: 27th Mar 2011, 15:47 -
100% compression rip re encoded?
By ironmanDD in forum Newbie / General discussionsReplies: 1Last Post: 23rd Feb 2011, 03:23 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
Single Episode Rip with MINIMUM Re-re-re-re-compression - HELP!?!
By jdmba in forum DVD RippingReplies: 6Last Post: 8th Aug 2008, 10:45 -
Best software to rip 'movie only' from dvd without compression.
By lordhutt in forum ComputerReplies: 2Last Post: 3rd Sep 2007, 20:37
