Results 1 to 30 of 42
  1. Member hiptune's Avatar
    May 2003
    Los Angeles, California
    I had a problem 6 months ago where my second hard drive went dead on me. It seems windows XP filled up the remaining space on the drive some how all by itself untill it wound it right out of commision. I rememeber seeing more data listed in exployer than I had on it but paid no attention. Eventually the drive becomes not accessable, and can't be cleaned or defraged or anyhting.
    I called Westeren Digital, and they said it sounded like a bad drive, and they sent another one out.
    Well, the same thing happened again. The drive which was storing some avi files was about 70% full, and I noticed it looked 95% the other day all of a sudden. So I deleted some of the least important files. NOw today the drive is not working at all and has gone dead just like that other one 6 months ago.
    Windows XP is filling up my slave drive and winding it up and out of commision.
    I have two Pent 4s, and this is the same one that killed the other extra drive.
    Can someone tell me what is causing this before I burn out another storage drive, and lose date I wanted to save for a future project?
    I doubt Western Digital will help again. And I do have an extra 80 gig'r around to install, but I think I have a bigger problem than just a dead hard drive.
    Please help!
    Thanks, Jeff
  2. Member 888888's Avatar
    Jan 2004
    Turdistan
    Wow that sucks. I am very lucky in that I have never had a hard drive "die" on me (crossing my fingers ). The worst I've had is a Samsung hard drive a few years ago that started developing bad secotrs (still works though).
    Anyway, Western Digital has a pretty bad reputation as far as defective hard drives and I have read reports of people having multiple WD hard drives die on them. I have however never heard of Windows XP causing the kind of issues you are describing. If nothing else, buy a better reviewed brand like Seagate next time. Also, there may be heat conditions in your case, although you should get warnings for that I think.
    Sorry I can't help more.
  3. If the drives weren't actually going bad it would seem like
    a program is backing up files to a hidden folder.
    You can check 'show hidden files' and look for some
    large files. That happened here, but our drives didn't
    fail, they just filled up.
    Karen
  4. Member hiptune's Avatar
    May 2003
    Karen
    Thanks Karen for the reply. I have a feeling something exactly like you describe is what happened. Except that the disc is completely full, so full that it has no room to read itself, and therefor is shot. Completely full like a cassette that ran off the hub at end. And now I can't get to the hidden files and see what did that.
    But I have an extra drive to drop in under the hood, and now that you have mentioned hidden files, I have somehting to go on next time. And my gut feeling is that there will be a next time.
    My otther Pent 4 has no issues like this one has had twice now.
    Jeff
  5. did you try and reformat it?
    format c: works for me!
  6. Mod Neophyte redwudz's Avatar
    USA
    I would suspect a virus or a trojan. You might want to download a few programs. Adaware, Spybot S&D, Spyware Blaster, HiJack This, or others.
    I doubt the OS is doing this.
    BTW, Western Digital is generally a well rated drive. I have had Maxtor drives go out on me, more than once. Maxtor, at least, doesn't really care what the problem is with your drive, they just replace it. That is their guarantee. I would just send it back to WD once again.
    Just general rule of thumb; Don't let your HD get more than 3/4 full. You need a little room for virtual memory, where your OS uses your HD for extra processing space. If you don't have a lot of system memory, you especially need HD space.
    IMO, probably the hardest use of HDs is defragging. The HD has to jump back and forth through the sectors and reallocate space fairly quickly.
    Anyway, your problem doesn't seem normal. I would try to see what is causing it besides the OS.
    Shadow57 has a good point, also. If you have installed backup software such as Ghost, it can use a lot of HD space.
  7. Originally Posted by 808smokey
    But then Jeff would lose all of his files.
    Karen
  8. Banned
    Sep 2004
    Inner Circle of Thought
    I have two Western Digital drives that are about four or so years old and they are still going strong.
    I recommend WD drives.
    Unless this is a dual boot system, you do not need an operating system on a slave drive.
  9. Member lumis's Avatar
    Jan 2005
    the remnants of pangea
    this might sound like a dumb suggestion, but are you using any norton anti-virus software?
    it has that norton protected recyle bin, and you've got to "double-delete" files if you're deleting stuff with the shift+delete command and think you've really deleted stuff. i hadnt used nortons in years, and this was one of their new features..
    i used norton internet security & norton anti-virus for about 2 weeks, it screwed my computer hardcore.. i tried uninstalling, but everything was still running at a crawl.. i wound up formatting & doing a fresh install of xp.. everything is zipping along great now.
  10. Member hiptune's Avatar
    May 2003
    Yes, tried to reformat it and message says "cannot format:
  11. Member hiptune's Avatar
    May 2003
    Karen
    I would give up all those files to get this hard drive back alive. I can recapture them. Time would be lost, but I have the tapes of those avis.
    No reformating, and no defragging, no disc clean up, no nothing, except a weird serial number, or model number that means nothing comes up in explorer, and does not follow Western Digital codes, or so they said last time this happened.
  12. Member hiptune's Avatar
    May 2003
    I run my internet through a router, and that includes a hardware fire wall. No Norton or any other things running that I know of. And I run addaware often.
    So I think one of my editing software programs is saving some files, or some notes on my editing. Some of them do that. I have seen those files before, but figured that they were very small. Something duplicated, and Karen is on the right track I do believe.
    Thanks for all the great ideas about what this could be.
    Its depressing slightly, as I have a video card problem on one machine (I think, as the cursor locks up while clicking and dragging things if I move too fast), and have a dvd-ram-rom drive on the other that konked out, and does not register any more. I had a TCB-1000 that did nothing when I turned it on right out of the box, and that was returned to fix. So I have had a hell of a time keeping two sinple Pent 4s with XP and burners with dual hard drives.
    2 nice computers I built myself, and gee......many defective parts, dying HDs, dvd reader quits, TBC that does nothing right out of the box. Oh and that is not counting my Epson R300, we all know what happens with those printers eventually. It has been a bumpy ride alright.
    Anyother ideas are very welcome. I need all the help I can get, as I am not sure if Western Digital should have to replace this, or should I even ask?
    Jeff
  13. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    powersupply can kill drives dead
  14. Originally Posted by hiptune
    Jeff
    One more idea.
    If you're using Internet Explorer to access
    the internet, do you delete your temp files?
    You would go into...
    Tools---->Internet Options---->
    Temporary Internet Files---->Delete Files
    We had a computer here that almost stopped completely.
    We found 10gb of files in the Internet Temp folders!
    Karen
  15. I was going to mention two things I already see. Power supply or virus...
  16. Member lumis's Avatar
    Jan 2005
    i can understand a power supply killing a hdd, but not filling it up with data.
  17. Originally Posted by Shadow57
    Karen
    If the drive fills up with crap and is unusable then I would reformat it, the "bad drive"
  18. Member hiptune's Avatar
    May 2003
    Karen
    As I already said, this drive can not be accessed. It does not take a reformat, defrag, install, anything. It became so full that it can't even look at itself. Like a VHS tape that comes off the end reel.
    There is nothing readable to reformat.
    End of the line for this drive.
    Jeff
  19. Banned
    Sep 2004
    Karen
    Jeff
    Are you trying to format c from the c drive?
  20. Member hiptune's Avatar
    May 2003
    No, this is drive D:, the extra storage drive, not the main OS drive.
  21. Banned
    Sep 2004
    You need to format from the A drive.
    That is why the format command would not work.
    Get a dos bootup floppy and type in the format command.
  22. Member hiptune's Avatar
    May 2003
    The A drive is the floppy drive. It cannot be reformatted.
    First you asked me about trying to reformat the C drive, then I told you no, it is the D drive with the problem of being "out of order".
    And now you are talking about the A drive?
    Please read the thread, the C drive with Windows XP is fine. The D drive (used for extra storage of avi files), is now full and the OS can't even read anything about it, not its size, model #, nor any files on it. It can't even defrag it. The drive likely can't even spin anymore it became so full.
    I guess I could totally erase my C dive and reformat it, and reinstall XP and everything. But that would not bring my D drive back to life. Now would it. So please don't suggest all that work when it would do nothing to solve this problem.
    I do not care about this drive anymore. I now am only concerned with protecting a new drive I will install. As this is the second time this happened.
    Jeff
  23. Member
    Aug 2001
    Finland
    Looks like you need a low level format, that's what the comment including a: refers to. There's probably low level format tools available from Western Digital (I don't know, to me they're the worst HD supplier as I'm concerned about noise level over anything else). So you need to download a low level format boot floppy image, create a floppy of it (at this stage I'd open the case and completely disconnect your master drive and switch your slave's jupers as master & connect as master) -> then, boot from this floppy containing low level formatting software and really sweep off everything there useed to be.
  24. Banned
    Sep 2004
    Jeff
    You are misunderstanding me.
    From the dos command prompt, type in a:
    When it switches to the a drive, type in format c:
    You need to have the dos boot floppy in the floppy drive.
  25. Originally Posted by bazooka
    Jeff
    That's what I was referring to. I was just a little lazy in my typing. Sorry
  26. I can't tell from your profile, but are you overclocking? I had a few problems with hard drives on an older motherboard that wouldn't let me lock
    my PCI bus at 33.33 MHz. Running too far out of spec isn't good.
    J
  27. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    Western Digital
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
  28. Member Skith's Avatar
    Bottom of the ocean
    If this is happening after heavy access, heat (temp) can be an issue. I had a WD drive shut down once from heat (ext enclosure). The drive just gave an error and vanished. I had to pop open the case, (it was hot to the touch) and let it cool. Reconnected and it worked again. So make sure your case has good cooling. IMO any large HD should have some sort of air flow across it, especially WD drives, you could cook an egg on those (don't try).
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  29. Banned
    Nov 2002
    Pgh Area
    To quote a tech site I read, "Pack the computer in the original box and send it back to us, you are too dumb to own a computer."
    That's a joke, though some of you will jump on me for it.
    Get to an a:\ prompt, best with a Boot Disk, choose "Start computer with CD ROM support, allow it to run its course, will give you an a:\ > prompt.
    From here you simply type "format: (insert drive letter here)
    "This will erase all data on the (insert letter here ) drive. Do you wish to continue? y/n
    Type "y" and sit back, that drive or partition will be formatted.
    DOSS doesn't give you the protections that the OSs do, or the errors, such as "This appears to be an external drive", or "Windows cannot format this drive."
    It just does it.
    Go get a 98 Boot disk if you need to.
    Cheers,
    george
  30. Banned
    Sep 2004
    That line always cracks me up.
    There are some that should not ever have a computer like my father in law.
