My graphic chard is a Radeon 7200 64MB DDR.
When I restart the computer from windows, the system take long to restart and when it does so, the image is completely blurr or even black with a few lines and often windows does not start.
If I start the computer (from the computer off), no problems occur.
I had the problem with my last ASUS A7V266-E motherboard too. I had the graphic chard repaired and it thent worked fine for a while.Then the problems started again. Bying a new motherboard (ASUS A7N8X-E Deluxe) did not solve the problem.
Lately, I had the graphic card sent to ATI again (it is still on warranty, and they sent me a new one(at least the serial number was different) but it did the same as the previous one).
I sometimes get messages during the POST of system failure due to CPU Overclocking, but I have everything set to yhe default options.
I have all the last drivers and have flashed the bios.
Setting CPU external frequency to 166MHZ, and setting memory frequency to 100%, as I was suggested, did not help, instead it make it worst as the system would not start at all and I had to reset the bios.
Thank you for any help,
Yoram
yoram
well if you replaced the vid card and the mobo you might wanna look at the ram next.
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
I would suspect the RAM also. If you can substitute memory sticks, or if you have 2 sticks, pull one out and try each separately. You can also try memtest86 that does a fair job of testing memory. http://www.memtest86.com/
I forgot to say in the previous message that I had already tried to swop the memories, but they are either both corrupt because this did not solve the problem.
I did tried a different graphic card and had no problems. When I put mine back in, I restarted the computer and it was fine, the second time it was bad again.
I also did tried to unable the graphic card in safe mode. The first time I restarted, it was fine, the second time the image was blurr and the third time the computer hang on a black screen.
When I did the tests with the Memtest, I had a funny thing happening, the CPU was of 1234Mhz instead of 2078Mhz (it went back to 2078 after a while). Errors were detected by thousands, I think. I have read that with AMD Athlon, the Memory must be of good quallity, mine were cheap. I will buy a new one, the problem is that I do not know which to buy.yoram -
AMD CPUs aren't so sensitive to memory problems, but ASUS MBs are reported to be. I run 1024G of Corsair Value Select memory PC3200 (512 X 2 pack) in a ASUS A7N8X-E computer.
It's a lower end memory for about $170US for the pair. Works fine with dual channel.
If you are into overclocking or gaming, though, you might look into some higher priced memory. -
i would check asus's web site to see if your memory is compatible. could be be a conflict with the memory
Ati Radeon 3200 HD no overscan [SOLVED]
By carlos28355 in forum Media Center PC / MediaCentersReplies: 33Last Post: 9th Sep 2011, 10:38 -
ATI Radeon 4870 HDMI audio
By shorto in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 20:56 -
ATI Radeon Pro 2400 to TV
By bulletb1331 in forum Media Center PC / MediaCentersReplies: 8Last Post: 27th Jun 2008, 14:52 -
Visiontek ATI Radeon HD2400 Pro Help
By mattman1968 in forum ComputerReplies: 2Last Post: 11th Jan 2008, 12:13 -
What do you think about the Ati Radeon 2600 hd pro?
By davidsama in forum ComputerReplies: 4Last Post: 18th Nov 2007, 15:25
