Hi, I have got an OGM that I have made into a m2v and got 2 audio tracks and 1 subtitle track. I tried DVDAuthorGUI but that didn't work and I can't afford DVD Lab Pro, does anyone know of a program that can support multipul audio and subtitles.
If you can tell me what didn't work, I may be able to help you with DVDAuthorGUI. Be as specific as possible.
OK, I had 2 OGMs with 2 audio, 1 subtitle. I made the avi's into m2v's, I then joined the 2 m2v's with Movie Joiner. When I put the ac3 and srt with the joined m2v into DVDauthorGUI it started working until it got to where the second m2v was joined. It just had an error and went back to the main screen.
DVDLab Pro is free for 30 days.
The problem you got is most likely a not properly joined m2v.
Use tmpgenc mpeg tools to "merge".Cheers, Jim
My DVDLab Guides -
I would tend to agree, but I would would really like to see the exact error message. I am guessing since you are joining m2v files, that you are receiving a '**ERROR: [???] Need to split output but there appears to be no %d in the filename'.
If this is the case, you can use restream to remove the 'end of sequence' markers out of the m2v file. -
I joined up the m2v's in tmpgenc, it works perfectly when I play it on the computer with sound and subs. But when I add it into DVDAuthorGUI with the 2 audio and 1 subtitle track I get this Error:
DVDAuthorGUI 0.997 - 12/17/2004
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
**ERROR: [???] File unrecogniseable!
INFO: [???] File C:\Anime\Fuma p1 eng.ac3 looks like an AC3 Audio stream.
INFO: [???] File C:\Anime\Fuma p1 jap.ac3 looks like an AC3 Audio stream.
**ERROR: [???] Unrecogniseable file(s)... exiting.
*processing subtitles for title: 1 sub 1...
The system cannot find the file specified.
erase "C:\Anime\Lupin\dvd\presub.mpg"
Could Not Find C:\Anime\Lupin\dvd\presub.mpg
echo *authoring title(s).....
"E:\Program Files\DVDAuthorGUI\bin\dvdauthor.exe" -x "E:\Program Files\DVDAuthorGUI\config.xml"
DVDAuthor::dvdauthor, version 0.6.10-2773.
Build options: gnugetopt iconv freetype
Send bugs to <dvdauthor-users@lists.sourceforge.net>
INFO: Locale=C
INFO: Converting filenames to US-ASCII
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing C:\Anime\Lupin\dvd\title1.mpg...
ERR: Error opening C:\Anime\Lupin\dvd\title1.mpg: No such file or directory
erase "C:\Anime\Lupin\dvd\*.mpg"
Could Not Find C:\Anime\Lupin\dvd\*.mpg
echo *process complete
*process complete -
It appears mplex is having trouble recognising the new m2v file. I would take reboots suggestion on joining the mpegs
multiAVCHD misses multiple audio or subtitles tracks
By Japo in forum Authoring (Blu-ray)Replies: 2Last Post: 24th Jun 2011, 19:26 -
How many audio tracks and subtitles are possible?
By dvdplanner in forum Authoring (DVD)Replies: 3Last Post: 5th Jan 2011, 08:46 -
Converting .ogm to mpeg-4 with subtitles and multiple audio tracks
By Weasel3689 in forum ffmpegX general discussionReplies: 1Last Post: 23rd May 2009, 12:34 -
authoring DVD with 2 audio tracks and soft subtitles
By Agent1266 in forum ffmpegX general discussionReplies: 6Last Post: 2nd Oct 2008, 16:34 -
Automating DVD to Divx 6 With All Subtitles, Audio Tracks, Chapters
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 20th Jan 2008, 18:33
