  1. I have a VOB file and when i try and demux it, it gives me this PCM file that my software wants to convert to WAV. That is fine but when i do it, it makes the WAV file inaudible. It is all staticy and hissy. I tried a couple conversion programs to do this and none seem to work. Does anyone know how i can get the PCM file to convert to something that has the original audio??
    Thanks.
  2. have you tried demuxing it with DVD Decrypter, and selecting Tools> Settings > Stream Processing Tab > "Convert PCM to WAV" checkbox?
  3. I have never demuxed with DVD Decrypter. How would I go about doing that?
  4. Member Soopafresh's Avatar
    Jan 2004
    dvd2avi will allow you to save the audio off the vob as WAV
  5. I got it to work with VOBedit. Thanks!
