hi- i have a packard bell imedia desktop-with a toshiba 4x dvd-rw and cdrom combi drive-i can only burn at 1x,i used ridisc and they burnt at 4x,but only played on 2/3 standalones- any ideas??
You may have Direct Memory Access(DMA) turned off.
Check and see if it is turned on. -
Packard Bell still makes computers?
DEAR GOD IN HEAVEN WHY!?!?!?!?!?? -
The Packard Bell trade name and a lot of other 'good old American' names were bought up by offshore companies.
Anyway, if one of your discs burn at the rated speed, it just sounds like a media problem. This can also relate to settop player problems. Take a look to the left under writers and players, <<<<< for both your burner and your settop player and see what is recommended for your setup. You could also check on your media, if it is listed.
It sometimes takes a bit of work to get the right combination. -
They only pulled out of the Pc market in the United States. They still make computers elsewhere. I have worked on a pack of snails computer b4, and I was not impressed. The Cmos battery was soldered to the motherboard so that it could not be replaced.Originally Posted by Gurm
How to Burn at 16 speed or better with 4 burners
By burn master in forum User guidesReplies: 9Last Post: 30th Mar 2010, 20:49 -
Dual Layer Burn Speed
By webstar in forum MacReplies: 8Last Post: 17th Sep 2009, 01:37 -
burn speed for videos
By gameroftheuk in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2008, 12:51 -
I need 'burn speed over ride'
By theewizard in forum DVD & Blu-ray WritersReplies: 15Last Post: 13th Jun 2007, 00:25 -
What Speed should I burn DVDs?
By Sudden Impact in forum Newbie / General discussionsReplies: 6Last Post: 9th May 2007, 07:11
