The new version works great from my hard drive.But if I make short cut on my desk top it work work it comes up with languag error and others
What is the error?
SVCD2DVD.EXE
Common Langue Runtime Debugging Services
Procedd id=0xc2c(3116)
Thread id=0x520(1312)
Version: 2.0 RC1
Type: System.NullReferenceException
Source: Interop.CodeLock
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at CodeLock._Secure.Authenticate(String pass)
at AxCodeLock.AxSecure.Authenticate(String pass)
at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426) -
Are you saying that if you start it from the programs menu or from the executable it is fine, but you get this error from a shortcut on the desktop?
Yes if I open it from my hard drive it works fine.When I put a short cut on the desktop I get that error.
What about when you open it from the Start->Programs....
keyboard shortcut needed
By angryassdrummer in forum ComputerReplies: 3Last Post: 6th Jun 2011, 08:58 -
Old General Electric VHS Desk
By loster in forum Capturing and VCRReplies: 2Last Post: 15th Mar 2010, 18:22 -
seagate freeagent desk 500gb and Western Digital TV
By damorsoft in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Jan 2009, 18:48 -
shortcut GfDA
By lordsmurf in forum FeedbackReplies: 2Last Post: 7th Dec 2008, 23:50 -
New Desk Top for Video editing
By NP11073 in forum ComputerReplies: 1Last Post: 2nd Nov 2008, 07:17
