  1. Hi, please can someone help me with burning a dvd-r in raw mode, in k3b i have the option to burn in raw mode in the cd-r section but not in dvdr, is there a way of doing it in k3b? or is there any other software that i can use on linux to burn in raw mode onto dvdr's
    im running fedora core 3 if tht helps
    cheers
    Moejoe
    Apr 2003
    Well I run Mandrake and their is a DVD addition to k3b that lets me burn a DVD structured directory or DVD iso. So I would guess that their is one for fedora.
  3. I would say he has k3b-dvd based on what he said just burnign in RAW mode is the issue.
    Never dabbled in the modes when burning before so haven't got alot of information there.
    xcdroast might be a program you might find helpful
    AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
    Jabber: DaveQB@jabber.org.au
    2.6.29.3-desktop-1mnb
  4. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Raw is not available for DVD burning.
    K3B uses 3-4 tools for burning. CDRDAO, CDRECORD (without PRODVD enabled) GROWISOFS, and DVD+RW tools (to erase and format +/- RW discs)
    Just wondering why you want to do anything besides DAO?
    XCDRoast does use cdrecord with PRODVD, however
    DVDs may be written in SAO mode or in packet
    mode. Cdrecord currently only supports SAO mode.
    Cdrecord-ProDVD-1.11a35 and later allow to specify
    -dao for correctness. Later versions of cdrecord
    will only write DVDs if dao is specified.
    ftp://ftp.berlios.de/pub/cdrecord/ProDVD/README
    I would guess DVD burning supports only Disc At Once recording.
