I have just used VCDeasy program to create the following file from a mpeg:
videocd.bin
videocd.cue
videocd.xml
videocd_for_firburner.cue
do I just burn these 4 files onto the cd as they are or do have to include the directoriers they are in???? This is my first try at this so don't know what i;m doing!!
Use any birner which recognises the bin/cue.
You will need to load the videocd_for_firburner.cue if you are goign to use fireburner to create the VCD. I think CDRDAO can butn the vue/bin files.
You can use any of these programs to burn Cue/Bin files:
CDRWin 3.8/4.0
BlindWrite Suite
FireBurner 2.12
CDRDao (using TSCV or VCDEasy or XDuplicator)
Ahead Nero v5.564 (was mentioned to now support Cue/Bin)
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 11:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
