Hi,I have a quick question.
I made whole Menu included text in Photoshop.
Now I opened the file in DVD Lab and tried to use Hot spot feature in DVD LAb.
I choosen text I want to link to movie.
When I used Simulate not only text was highlighted but also the rest around the text I choosen with Hot spot.
So it looks like square is highlighted with text inside which I almost don't see.
Can someone help me there??
Look on the Map tab.
Turn off the color for "normal" (slide it all the way left). Then the link (hotspot) will only be hilighted when selected and activated.
If you don't like the look when selected, turn the map off for that too.
I usually do this with switched menus, turn mapping colours off completely, and let the switching be the visual clue.
Another way around this, is to have a thin bar below the selection text, or an arrow pointing to it, or button, whatever.
Hotspot the bar/arrow/button, so only it has selected mapping colour, and your text stays the same.Cheers, Jim
My DVDLab Guides
DVD burn runs too hot, how to slow down reading the source disk
By loninappleton in forum DVD RippingReplies: 6Last Post: 28th Apr 2012, 09:31 -
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
HOT DEAL: St. Louis Craigslist - $75 JVC DR-M10 DVD Recorder
By jbd5010 in forum Off topicReplies: 2Last Post: 16th Mar 2011, 09:21 -
Name of feature that allows DVD/Blu-Ray players to remember spot when off
By Dreadnaught in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Feb 2010, 19:14 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 07:45
