im trying to create a dvd with multiple titles in sizzle and having no luck. when i encode dvd ffmpeg this works ok, but then i need to demux the file and i end up with a million m2v files.
i tried to dvdmpeg2enc but it says failed everytime.
anyone know what process i should use to get the correct file that sizzle will accept?
thanks
sorry, i can not find the normalize option (im using version 0.0.9r)
also, which preset do i need to use to encode the correct file for sizzle?
thanks again for your help
Audio lag after conversion to DVDmpeg2enc
By macgurl in forum ffmpegX general discussionReplies: 5Last Post: 8th Aug 2010, 03:42
