I burned a movie on a ritek dvd-r the printable 4x ones and it's having problems. Now these are usually known to be good discs but lately, they've been pretty iffy. I noticed if the you get tiniest scratch it won't read at that area. Last night I burned a dvd to one of these disc and when it got towards the end of the movie it wouldn't play frozen, would skip a little bit then freeze permantly and say disc error. This disc has no scratches or lint on it at all. I put the movie in 5 dvd-rom drives and it can't read the end of the disc either. Could this just be a bad disc? Makes me wonder about the other 50 I've burned alreadyIs there anyway I could extract this movie off this disc to burn another copy? I'm thinking it's gonna be hard to decrypt this one since the end is goofed up. Any ideas? thanks in advance
Results 1 to 9 of 9
I just scanned the disc with nero cd-dvd speed test and towards the end the spikes drop down and it says uncorrectable error. I tried to rip the movie to my harddrive using isobuster but when it gets to the Vob that's bad it refuses to save it. Dvd decrypter doesn't even want to open the disc. What can I do to extract this off the bad dvd and burn it again. there is absolutly no scratches or spots or dust or anything on this disc. I don't think I'll be buying the ritek g04's again anytime soon.
Originally Posted by nick101181
I know you can change the number of times it retries a given error spot on the disc, but I very seriously doubt you're going to be able to extract the whole disc. I also think that having ISObuster running for a long period of time trying to extract large numbers of errors is not exactly the best for your drive.
You'd probably be better off trying the disc on other drives one at a time if you cannot get it to work on one drive. I know my Toshiba 5112 has been able to recover a few discs that none of my several other drives was able to extract. -
My theory regarding some inkjet printable DVD-Rs is, that the same problem occurs as with paper labels: The printable top layer is warping the disk slightly at the higher temperature in the DVD drive. This might occur, if the printable top layer and the other plastic of the disk have different temperature expansion factors. If the disk is slightly warped, then on the outer side the laser optics can not focus properly.
Are you sure you have RITEKG04 and not RITEKM02? RITEKG04 is no longer in production.
I propose:
- Start ISOBuster and try to read out the data.
Then follow this sequence:
- Wait until an error message occurs.
- Press the eject button of the DVD drive so that the tray opens.
- Wait for 15 minutes so that the DVD-R disk becomes colder.
- Close the tray.
- Click on "retry".
Repeat the sequence for every further error message.
Good luck. -
Yeah I have ritek g04s. I'm gonna try what you suggest then I'll post the results.
Ritek RiData G05 vs RiData Pro Series - Anyone know the difference?
By DVantrease in forum MediaReplies: 5Last Post: 1st Jan 2009, 15:48 -
How about some RiData DVD+R DL discs...?
By JohnnyBob in forum MediaReplies: 31Last Post: 26th Apr 2008, 08:30 -
Verbatim or Ridata DVD-R
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 01:57 -
How is RiDATA DVD-R for Pioneer DVR-111D
By Mickey79 in forum MediaReplies: 20Last Post: 9th Nov 2007, 11:06 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 10:41
