Using Release Candidate 1 with Windows XP Pro SP2, I frequently receive
the following error message, must often when trying to open another VTS.
If I select Quit and start over, I may or may not get an error again and when I do, the Parameter Name '-21' is usually different.
I see the image of the error message didn't take. It says
"An unhandled exception has occured in your application. If you click Continue, the application will ignore this error and attempt to continue.
If you click Quick, the application will be shut down immediately.
Specified argument was out of range of valid values.
Parameter name: '-21' is not a valid value for 'displayIndex'. -
Do you get a stack trace?
It occurs when I am loading the assets and creating a second or third VTS before processing. This is the text from Details. I apoligize for not including it originally. I intended to do so.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Specified argument was out of the range of valid values.
Parameter name: '-18' is not a valid value for 'displayIndex'.
at System.Windows.Forms.ListViewItemCollection.get_It em(Int32 displayIndex)
at System.Windows.Forms.ListView.LvnBeginDrag(MouseBu ttons buttons, NMLISTVIEW nmlv)
at System.Windows.Forms.ListView.WmReflectNotify(Mess age& m)
at System.Windows.Forms.ListView.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly Version: 2.0.1843.19197
Win32 Version: 2.0.1843.19197
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
DevComponents.DotNetBar
Assembly Version: 4.6.0.0
Win32 Version: 4.6.0.0
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/DevComponents.DotNetBar.DLL
AxInterop.CodeLock
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
Accessibility
Win32 Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
Interop.CodeLock
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
Interop.QuartzTypeLib
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/Interop.QuartzTypeLib.DLL
System.Design
CodeBase: file:///c:/windows/assembly/gac/system.design/1.0.5000.0__b03f5f7f11d50a3a/system.design.dll
SVCD2DVDLib
Assembly Version: 1.0.1839.37055
Win32 Version:
CodeBase: file:///D:/Program%20Files/BadgerSoft/SVCD2DVD%202%20BETA/SVCD2DVDLib.DLL
Microsoft.VisualC
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.3052.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualc/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualc.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
Also, where so I find my Preferences or Option at this point so I can turn on the JIT debugger
Once again, THANKS for making this program available and your continued help.
TSPE error in version 0.76 - Index was outside the bounds of the array.
By bildry in forum EditingReplies: 0Last Post: 9th Apr 2010, 14:56 -
VOB2MPG Index out of bounds error when trying to convert some DVDs
By secretsubscriber in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 1st Mar 2010, 09:35 -
BD INfo Error : Index was outside the bounds of the array
By ripper1234 in forum Blu-ray RippingReplies: 0Last Post: 28th Jun 2009, 08:29 -
Avi index error in vdubmpeg2 - how to correct?
By yoda313 in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 20:44 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
