I have the following problem with ffmpegX: when I load a VOB file, it will oftentimes not give the correct video size of the movie. It seems that ffmpegX will give a standard size like 720 x 540 when the actual size is different, and more importantly, when the aspect ratio is different. This leads to (if not corrected) a distorted encode, where the image becomes too narrow or too wide, whatever the case may be.
I've tried finding some small application that will tell me straight up how big my video is, and what sampling is used (Pal/NTSC/NTSC film) without failing. I've also tried finding if maybe I'm doing something wrong. The way I deal with this now is quite cumbersome: I open up the movie in VLC, then take a screenshot, open the screenshot in Photoshop and look at what size the image is. Cumbersome, dumb and often somewhat inaccurate.
Can anybody help? Could the developer chime in?
Thanks in advance.
(this is a follow-up to the versiontracker post where I made this point)
Please email to major4@mac.com with screenshots or clips.
ffmpegX should always recognize the correct source video size in the left-side LCD screens. Please note that when playing a video file, a pixel aspect ratio correction may be applied by the player and opening a screenshot in Photoshop has no meaning in respect to determining the source video size.
It is however possible that the output size (right-side LCD) is set incorrectly in some cases.
Are you running ffmpegX from an account with Adminstrative privileges? ffmpegX returned similar, incorrect results for me when running from a Normal, non-Admin account.Originally Posted by Thunderkopf
Changing aspect ratio of video files in iso so for burning w/ correct a/r
By cinesimon in forum Authoring (DVD)Replies: 6Last Post: 10th May 2011, 03:40 -
How to determine proper video size and aspect ratio?
By Bonie81 in forum Video ConversionReplies: 13Last Post: 25th Apr 2010, 03:57 -
Correct aspect ratio
By dfisher052 in forum DVB / IPTVReplies: 8Last Post: 26th Oct 2008, 00:34 -
How to correct the aspect ratio (I see it in 4:3 but it should be 16:9)?
By Anonymous74 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2008, 08:10 -
how to correct the aspect ratio of AVI
By edong in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2008, 19:04
