Hi, Major!
My problem is:
When trying to convert from an .avi to DVD, using the Quick Preset ffmpeg DVD encoder (the mpeg2enc gives me a black image, as usual, never worked for me) the result is a file with a nice image (as usual), but no sound.
The Play button makes MPlayer playback the source with no problems, but the Preview button doesn't work, now.
When getting informations on the ffmpegx progress, I notice there is no Stream #0.1 (the sound)
With a previous version (0.0.9p, I guess...) everything was just fine.
I don't understand why this happens. Can you give me a tip, please?
I use a PowerBook G4 1GHZ with OS 10.3.7.
Thanx in advance
Art
Unfortunately, I ended with a 3.o1GB with NO sound.
As you know, the preset has the Video_TS author enabled.
I used to burn the Video_TS in Toast and it went always fine.
This time the app didn't even "make" the Video_TS "thing"...
What am I doing wrong, Major? It seems I'm not the only one having no sound on the encoded movies...
Art
Could you please email me the process outputs to major4@mac.com as well as a screenshot of the summary tab.
I've tried with 0.0.9.k (the other one available...) and the results are worse.
Both encoders (ffmpeg and mpeg2enc) produce movies with black images and no sound. Grrr...
Art
AutoGK: stopped converting/a MP2 audio to MP3 [TV cap--> xvid/avi encodes]
By bruckwine in forum Video ConversionReplies: 7Last Post: 18th Jun 2010, 01:46 -
AVCHD thru Premiere CS4 encodes hiccups in audio
By ddane in forum Video ConversionReplies: 5Last Post: 11th Dec 2009, 17:21 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 01:10 -
New PC - Encodes not as good...
By Browncoat in forum Newbie / General discussionsReplies: 28Last Post: 17th Jan 2008, 18:39 -
Audio sync consistently off on some dvd rip encodes
By carmat06 in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 20:07
