Hey
I have been ripping a few dvd's and have come across a problem regarding the type of stream the vob file is.
I rip using dvd decrypter stream processing - all fine.
Then i go to use dgindex to extract the stream and it will not open it - says
"Mpeg1 streams not currently supported"
I don't know wether it is because the dvd is encoded at mpeg1 or somehting i am doing
I also tried using dgindex directly on the dvd files and still same thing
Any ideas
I am using dgindexto extract the video, audio so i can use gordian knot to encode to avi
DVD Ripping problems with cucusoft
By oki4life in forum DVD RippingReplies: 1Last Post: 27th Nov 2011, 18:44 -
Audio problems after ripping DVD
By ksimz202 in forum Newbie / General discussionsReplies: 3Last Post: 28th Mar 2011, 02:49 -
Problems ripping my DVD
By KayAt in forum Newbie / General discussionsReplies: 2Last Post: 11th Feb 2009, 17:33 -
audio sync problems after ripping dvd
By blubot in forum Video ConversionReplies: 4Last Post: 23rd Sep 2008, 11:14
