Alright i got a movie i would like to encode which has a resolution of 640x480. Now from reading guides and whatnot its suggested that you round down the resolution which in my case would be 352x240 which i find really low. I encoded at 5371Kbps 2-pass VBR with a resolution of 720x480 and i must say that it actually looks better than the source file. So should i reencode at 352x240 or just leave it? Does 352x240 look as good as 720x480 on TV? Thanks![]()
Your choices are 720x480 and 352x480, 640 is closer to 720 and would probably look OK. I use 352x480 quite a bit and I'm happy with it, looks good on my 26" TV.
edit: No way 352x240 is any good at all.
"Art is making something out of nothing and selling it." - Frank Zappa -
Unless your source is questionable quality 352x240, then resizing it up actually LOSES quality.
Cheers, Jim
My DVDLab Guides -
Bah, i always forget about Half-D1 :P Thanks
edit: Will the final size be smaller when using a smaller resolution or is it dependant on the Bitrate? -
It's all bitrate. Aspect ratio/size has (almost)nothing to do with filesize.
BTW, 352x240 is 1/4D1
Cheers, Jim
My DVDLab Guides -
I ment i forgot about 352x480 which i think is half-D1. Question: If the movie is at 23.976FPS do i need to enable 3:2 pulldown? thx
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
