Hi there, I know it sounds odd, but does anyone know how to create or introduce MPEG artifacts in a video on purpose. It's an effect i'm looking for, for a project i'm doing, and i'd like to have them inserted in certain parts of the picture. Just like a "trail" of "macroblocks" when an mpeg is corrupted, or something similar... I don't want them randomly inserted, but insert them on purpose in certain parts as an effect... So corrupting the mpeg manually won't do...Any clues? I use Adobe Premiere and After Effects btw... Thanks!
Ike.
Isolate a section and re-encode it with a lower bitrate - much, much lower than it needs. This should have macroblocks and pixelations all over the place. You'd then just have this clip as a play item on your DVD or whatever you're creating.
If in doubt, Google it. -
Finally something I'm a MASTER at! But jimmalenko beat me to the topic.
I do have one possible suggestion however. Use BBmpeg for a couple of seconds longer than you need at an excessively low bit rate & you'll get more artifacts than you can stand.A good divorce beats a bad marriage.
Now I have two anniversaries I celebrate! -
Mmmm... sounds interesting. I could actually reencode the whole video on a veeery low bitrate, then have it as another layer on my editor, and mask the parts I want to affect/effect... shouldn't I? Sounds great!! mmmm but... in that case I would be getting big nasty macroblocks that actually correspond to the blocks in the picture. When a file is corrupt, what you usually get are blocks (B and P blocks) that have to be decoded without their original I block... know what I mean? Jeeezz... it's quite difficult to explain. Let's see, if a hand comes in the picture, and just there you have an error, the decoder has no blocks to refer to, so what you get is a dirty area of "invented" blocks... get it? Would I get that with a very low bitrate...?
Well, whatever.... your advice is good enough for now I guess. I'll give it a try, and experiment with it. Your tips got my mind working! Thanks a lot!!
Ike.
creating many small clips w/ mpeg ts file
By Funkymoses in forum Newbie / General discussionsReplies: 1Last Post: 6th Sep 2010, 12:53 -
Blocking Artifacts in MPEG-4 AVC / H.264 Video
By Eva-Unit01 in forum Video ConversionReplies: 0Last Post: 28th Aug 2010, 15:36 -
creating small mpeg with delay between frames
By nighthawk2018 in forum Newbie / General discussionsReplies: 11Last Post: 30th Dec 2009, 10:56 -
WMV vs. MPEG compression artifacts?
By smexxy in forum Video ConversionReplies: 5Last Post: 17th May 2009, 00:33 -
Creating MPEG 4 Clips
By travelerkgd in forum MacReplies: 6Last Post: 8th Nov 2007, 23:29
Any clues? I use
