I'm a newbie in video editing. I have transferred captured video from my mini-dv to my laptop (using firewire).
Question 1: will i get better video quality if i burn the captured video to a dvd compared to burning on a standard cdr? I intend to playback the video on tv using a standard dvd-player. I'm thinking of getting an external dvd burner but i want to make sure first that i can actually benefit from it in terms of better quality video & audio.
Question 2: will i get better video resolution using firewire cable transferring video from handycam to laptop compared to usb 2.0 cable? I know it's faster but would it actually make a difference in terms of video & audio quality?
Many thanks!
DVD is unequivocally, unquestionably better than VCD ... with the only caveat being a sub-par source, which is irrelevant in this case given a MiniDV source.Originally Posted by Theus
Check out What is DVD and What is VCD (both found top left) for the specs for both formats, and you'll see that all of the things that equate to better quality (such as frame size and bitrate limits) all point to DVD as better. There's also a comparison table at the end of each section (here), which compares a whole heap of formats against each other.If in doubt, Google it.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
