I have become a procoder fan for my DV to mpeg2 encoding. However, in many cases i'd rather not do all the demuxing/muxing and all the other steps involved with all seperate apps. Which all-in-one do folks feel gives the best quality output? My assumption is it's one that allow you to use one of the "pay for" encoders like TMPGenc, Procoder, CCE, mainconcept, etc.
I think The Film machine and maybe a few others can use procoder but I haven't tested this yet - but I will.
Again, not limited to freeware, but not $200+ high quality all-in-one.
It's not an all-in-one converter if you need to install and configure several different pieces of software to do it. I don't understand what you are doing in your process if you have all these steps. DV - DVD is pretty straight forward.
I use Vegas, but there are cheaper alternatives that can do the same. My steps are pretty much edit and filter etc in Vegas, output from Vegas (video and AC3 stream), author in DVD Lab Pro.
If you seriously want quality, get the best tool for each job, rather than hoping some other persons canned settings will be good enough for you.Read my blog here.
Don't know for a fact but it's my understanding from a lot of posts that Media Studio Pro uses the mainconcept engine for encoding.... 8) Regardless I'm very happy with the results. It will accept just about any file you can throw at it.Originally Posted by tmh
It's all I use, I have a simple 3 step process. Capture to AVI>Edit in MSP then output to DVD Compliant MPEG w/AC3>Author (no encoding neccesary in this stage) It's more than your $200 limit but it's also much more than just a encoder.
Quality problem "caused" during "deinterlacing" ?
By Hombre_86 in forum DVD RippingReplies: 26Last Post: 25th May 2010, 22:28 -
".mkv" to "DVD" with CCE encoder
By chrchr in forum Authoring (DVD)Replies: 17Last Post: 28th Jan 2010, 14:01 -
"Any Video Converter" output format choices - can anyone explain?
By slipkid in forum Video ConversionReplies: 5Last Post: 14th Feb 2009, 18:09 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40 -
how to create "letterbox" bars with Total Video Converter
By zomigi in forum Video ConversionReplies: 6Last Post: 31st Jul 2007, 10:47
