hey all i downloaded the high definition trailer of sharktale,very goo quality,i was wondering if i would be able to encode my dvd's into xvid or some simiar codec to look like high definition quality,is this possible because i heard of a thread at doom9.org where they did this with increasing the resolution and using some filters but the files will turn out to be 4gigs or more,just want to know is this can be really done?
Technically - no. You can't make something higher quality than the source
Perceived Higher Quality - Kinda Sorta
The trick in the end is playing the file with FFDSHOW and its associated image filters. Better have a 3.0 P4 or higher to use it...
http://www.htpcnews.com/main.php?id=ffdshowdvd_1
http://home.new.rr.com/mnn1265/ffdshow.htm -
well sort of - but just get a HD uprez dvd player is a lot easier ..
but dvd resolution is not HD res. , even if you try ....
but pretty good looking on my system .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
http://www.compusa.com/products/product_info.asp?product_code=316197&pfp=BROWSE
Well my mom may buy this comp,would it be able to handle it? -
" Well my mom may buy this comp,would it be able to handle it?"
Probably...
High Definition Video on SD DVD
By TheLaserdisc in forum Authoring (DVD)Replies: 6Last Post: 19th Apr 2011, 22:42 -
High definition DVD
By rene-rottingham in forum Newbie / General discussionsReplies: 13Last Post: 21st May 2010, 07:35 -
How to burn high definition video to DVD?
By local2 in forum Video ConversionReplies: 1Last Post: 13th Dec 2009, 14:53 -
By local2 in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2009, 14:52 -
High Definition on DVD
By Dem Pyros in forum Authoring (Blu-ray)Replies: 24Last Post: 2nd Sep 2008, 09:48
