I am experimenting with re-encoding 720x480, 29fps, 6Mb/sec from plextor captures. I took an hour and half movie and compressed it a few different ways using tmpg express.
1) svcd , about 1.4gb (480x480)
2) vcd , about 1.1gb (320x240)
3) xdvd , about 1.5gb (720x480)
This is the first time trying to use "XDVD" I was shocked that I was able to make a 740 x480 that was this small in file size. I also think it looks less blocky then the others, and looks better.
Does anyone have an opinion on why I would not use xdvd instead of the other types for re-encoding?
Yes it takes a long time, but don't care.
Results 1 to 11 of 11
I use KDVD. Similar concept. Acceptable output (depending on source of course)
and if your player will play it properly.
Cheers, Jim
My DVDLab Guides -
What is 'X' about the DVD. The resolution is compliant, waht did you change to make it non-compliant?Originally Posted by zepolli1There are 10 kinds of people in this world. Those that understand binary...
Well it is a term coined by Tmpenc I think. If you use their "Express" package it will allow for XDVD output..
I think it is basically Mpeg 2 with a lower bit rate. I think it read something like 1600 vbr.
I have heard other people say this is the same as KDVD.
The output looks better on higher resolutions than 320x240 as far as I can tell...anyone else have an opinion? -
The average bit rate determines file size. whether it's VCD,SVD,or DVD if the bitrate is the same,the file size will be the same. Resolution does not effect file size. A 352x240 will be the same file size as a 720x480 file if the bitrate is the same. The easiest way to make an xDVD or XSCVD is with a progrma like DVD2ONE.
Well, that's why I said they lower the bitrate from what used to be 6000 bits/s down to about 1600bits/sec .
The question is, you must be loosing something. I guess probably color depth, transition smoothness..etc.
anybody have a link to xdvd info? -
You can go down to 100kbits/sec at 720 * 480 and it could still be DVD compliant. Low bitrate does not make it 'X' DVD. Something else has to be changed to make it a non standard DVD. Maybe the GOP structure used is longer than normal? That might help to maintain quality at lower bitrates in some cases.Originally Posted by zepolli1There are 10 kinds of people in this world. Those that understand binary...
No.Originally Posted by zepolli1
Nothing "x" about it.
And "kdvd" uses whacked out matrices, resolutions, and other non-compliance issues (though this continually changes and varies ... at any rate, not suggested).Want my help? Ask here! (not via PM!)
I posted this in a new topic to try to get more info..but from tempenc:
4. XDVD
Introduction of the XDVD (eXtended DVD) format.
A new format called XDVD has been developed based on DVD-Video standard, to allow longer hours. Though the length of GOP(Group of Pictures) is limited to 18 frames in the DVD-Video standard, concerning the XDVD format, one GOP can contain up to 60 frames! High-quality and high-compression can be realized in the same time. For instance, it is possible with that format to put 10 hours of video in a 4.7 GB DVD !!! -
Yeah, I know kdvd is totally out of spec, but they play in all my stuff
FWIW, I can get 16 hours, 1/4D1, on 1 dvdr. Great for cartoons
Cheers, Jim
My DVDLab Guides -
You consider 352x240/288 DEINTERLACE good for cartoons? Ugghh.Originally Posted by reboot
Interlace is EVEN MORE important for animation.Want my help? Ask here! (not via PM!)
100 million bucks in a savings account
By deadrats in forum Off topicReplies: 0Last Post: 30th Jun 2011, 22:55 -
Consider source as XDVD format MPEG file?
By headless chicken in forum Authoring (DVD)Replies: 10Last Post: 29th Sep 2010, 21:44 -
Benq 1620 $25 after instant savings
By bevills1 in forum DVD & Blu-ray WritersReplies: 4Last Post: 16th Oct 2007, 11:01 -
Savings that has the best interest rate???
By mol3000 in forum Off topicReplies: 3Last Post: 17th Aug 2007, 02:02 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
