Results 1 to 11 of 11
  1. Check Versiontracker.com
  2. Member terryj's Avatar
    N35°25.24068, W097°34.204
    saw that, thanks for the heads up!
    Anybody got this yet and tested if
    it is now faster than Popcorn
    in full disc mode?
    just curious......
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
  3. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Woohoooo, ARccOS support, yeah! It's already plenty fast for me in Variable mode, plus it allows me to choose exactly which audio tracks I want to leave out. Note that sweet dock icon progress bar from MTR 2.7... Been waiting for this one!
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  4. Member terryj's Avatar
    Urban Mac User
    Oct 2003
    www.mapquest.com
    WW. What is the use of ARccOS support if still MTR needs to fight it to rip it?? Will this version ARccOS do something differnt then the last version of DVD2oneX??? Thanks
    *New Mac user*, been PC user 4 life
    Oct 2003
    www.mapquest.com
    On dvd2oneX,, Is there really any big differnece in quality between Variable or Consistant??
    Ain't Variable quicker to copy then Variable?
  7. Member WiseWeasel's Avatar
    Jan 2003
    Most people don't have any problems ripping ARccOS DVDs with the latest version of MTR. If you're having problems, try it with a different drive. We can't make drives that refuse to skip over bad sectors suddenly work with MTR, as that's all handled by the OS through IOKit. If there are certain releases that won't rip with MTR on any drive, then that's news to us, and we need someone to send in those discs to us so we can get any problems with MTR fixed.
  8. Member terryj's Avatar
    you mean isn't Constant Bit Rate quicker than Variable bit rate?
    Answer: Yes, because Variable Bit Rate takes into account the
    type of footage ( varying degrees of motion/action vs. talking heads/
    static scenes) and encodes higher on static, less of action, whereas
    Constant goes for the same bitrate all the way through.
    So, if you are doing say the English Patient, Constant would be ok.
    But doing something like say, Matrix Revolutions, you would want Variable.
    Oct 2003
    www.mapquest.com
    WW, I have a External LG 5120D burner. dvd player and MTR does not work with it. When I put a dvd movie into my LG and open MTR, it says scanning on the bottom right side, but other then that it does not do nothing. To get MTR to read dvd movies I have to use my Mac Mini combo dvd drive and it works fine. Do you think there might be a compatible driver issue w/ my external dvd burner w/ MTR??
    As for Toast or Dragon fire,, my LG works fine.
    Terry, thanks for clearing that up. I have always used constant mode. So just to say, maybe variable would be better since its copys faster.
  10. Master of my domain thoughton's Avatar
    England
    he said constant was faster, not variable.
    Tim Houghton
    Website • Photography
  11. Member WiseWeasel's Avatar
    Jan 2003
    Regal, yes, there does seem to be a compatibility issue if DVD Player won't work with it. Not sure about any drivers, though you might try installing Patchburn and seeing if that does anything for you...
