  1. Hi,
    I've an Xvid video with hard subtitle. There is some way to extract the subs?? The best will be the possibility of adding another language subs..
    I hope Im been clear
    Thanks in advance
    h
  2. if the subs are glued to the image, then you canŽt remove them, cause after re-encoding , the subs are part of the image. The only way is to place a black matte over them...but then youŽll loose part of the footage
  3. So no possibility for me
    thanks
    h
