  1. DVDSrink can split film to 2 disks. But it is nessesaru for me to place a picture with messge "Insert disk 2" at the end of the disk 1. How could I do it?
    Apr 2004
    Miskatonic U
    You cant do it with DVD Shrink. DVD Fab can do this, and I believe DVD Remake can also be used to do this.
    Read my blog here.
  3. Member RickTheRed's Avatar
    Aug 2004
    Up north
    Use the reauthor mode.
    Drag the main movie as usual.
    Click full movie.
    Select "insert disc 2" files
    Click reauthor.
    Add selected files.
    Process to iso
    Burn with your pref application.
  4. Originally Posted by RickTheRed
    Click full movie.
    Click reauthor.
    Add selected files.
    Process to iso
    And how can I place a picture???
  5. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    do you want menu's?
    RickTheRed explained how to do it without menu's
    you could use the reauthor option and then use still image to replace the 2nd half of the movie with an insert disc 2 image. You can also crop most of the still pictures off as you wont need it to show for that long
  6. Member RickTheRed's Avatar
    Aug 2004
    Up north
    telekot,
    I guess you got it wrong.
    You are not placing a picture or *.jpg file.
    You are placing a small (500kb) video file.
    Google with "dvdshrink", you will rapidly find a site that you can download different "insert disc" files.
    Download them all and look at them using dvdshrink.
    From now on, you should be ok.
    I hope...
