DVDSrink, DVDFab and other programs can coding and burn disk itself. But Nero can burn disks too. What program better to use for burning? Nero or DVD program that has copied film? Nero or DVDSrink?
I use DVDDecrypter to burn iso's, Recordnow Max to burn VIDEO_TS folders. I use Nero to burn data only DVD's.
By choice, I guess. People do things differently. This is my method. I also have never had much success with using Nero to burn movies. Just my 2 cents.
I've never had problems burning movies with Nero. You select DVD-Video as the type of DVD, drag and drop the .IFO, .BUP, and .VOB to the Video_TS folder, and burn. If you select DVD-ISO, you're burning a data disc not a movie disc. Most software players are forgiving and will play the data disc but standalone DVD players will not successfully load data discs.Originally Posted by TELEKOT
How to burn DAO data disk
By logannsan in forum ComputerReplies: 4Last Post: 22nd Jun 2009, 13:17 -
Is there a problem with my DVD Burner? Blank Disk after a Burn?
By nadizo in forum Video ConversionReplies: 2Last Post: 1st Sep 2008, 03:18 -
How to burn music folders in a dvd disk?
By sumeshkri in forum AudioReplies: 20Last Post: 11th Mar 2008, 00:10 -
Burn in Disk Utility
By andredanton in forum MacReplies: 4Last Post: 12th Feb 2008, 13:41 -
Burn AVI file to DVD disk
By clms in forum Newbie / General discussionsReplies: 10Last Post: 20th Jul 2007, 15:10
