Hi all,
I have several video clips on my computer that are actually longer than they appear. Windows Media Player (classic & v9) will say the clip is 2 minutes long, and will play for two minutes.
However, if I move the time cursor to another part of the clip (the middle, for example) I'll see another part of the video, and THAT part will only play for a short period before stopping.
I've taken the video clips into Adobe Premiere and also into TMPGEnc and both only show the video having X amount of frames (short). The only video player that plays the clips correctly is my DVD software (e.g. WinDVD).
Here is more relevent information. One clip is 66.5 MB and only shows to be 49 seconds long. However, scrolling around inside the movie reveals that it's actually much longer (maybe 10 minutes).
Oh, and the timer in WinDVD does not function properly either. Although it plays the entire clip, the timer will show "1" for about 13-15 seconds, then "2" for another 13-15 seconds, and so forth until it finally reaches "49 seconds" several minutes later!
This is some kind of strange / bad encoding job, I'm sure. I just would like to know what I can do to fix it. DVD Software is so cumbersome compared to WMP, which open almost immediately on my computer.
Thanks, and BTW this site is great. I've been a lurker for a few years (since vcdhelp.com) and there is a WEALTH of information here. Hopefully the answers to this post will help someone in the future, including me!
Yeah this problem is common for DivX/Xvid,the header is usually the problem.
AC3 no longer works w/ WMP 11
By dmjerbear in forum AudioReplies: 2Last Post: 5th May 2009, 22:14 -
Video Sharing Site longer than 20 minutes
By xeroid in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:03 -
audio way longer than video
By sn0wd0g in forum DVD RippingReplies: 5Last Post: 14th Jul 2008, 00:58 -
Audio and video off if captured longer then 10 mins?
By Ghtpua in forum Capturing and VCRReplies: 4Last Post: 7th May 2008, 11:39 -
PS3 no longer detects WMP after disabling WFW
By taylordotcom in forum Media Center PC / MediaCentersReplies: 0Last Post: 20th Feb 2008, 02:15
