Hi, i have a friend who is in america and has been offered a sony dchr40e camcorder and she has several questions that need answering before buying it
1. will it record in NTSC???
2. if it does will it be viewable in this country???
3. if so can it then be put onto a pc and recorded as PAL???
4. or are they all compatible anyway ???
many thanks in advance for any advice and or help.......
Well from what I can tell from searching the web is that the Sony dcrhc40e is the PAL version, dcrhc40 is the NTSC version. So I would assume that
1 Will it record in NTSC??? –
No I will not record in NTSC.
2 If it does will it be viewable in this country???
– if your country uses PAL then yes.
3 if so can it then be put onto a pc and recorded as PAL???
Its already PAL.
4 or are they all compatible anyway???
No they are not compatible.
Deek -
hi,
both standards are not compatable but there is nothing stopping you, once the footage is on the pc, converting it from pal to ntsc, or visa versa
mixa
How can I display an XBOX360 from the UK (PAL) on a TV in America (NTSC)?
By ksamad1 in forum Newbie / General discussionsReplies: 0Last Post: 4th Jan 2011, 21:35 -
Buying my first Camcorder
By odedne in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 3rd Nov 2010, 11:47 -
I am thinking of buying a new HD camcorder
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 36Last Post: 2nd Jun 2010, 05:05 -
Buying a DVD player in Europe, using it in North America
By ChasssTO in forum Newbie / General discussionsReplies: 1Last Post: 5th Feb 2010, 14:41 -
Buying Camcorder
By Nanflexal in forum DVD & Blu-ray RecordersReplies: 9Last Post: 25th Jul 2009, 15:14
