Hi all:
I recently upgraded from Nero 5.0 to 5.5.2.4. Ever since then I haven't been able to burn one single CD. Sometimes the OS (Win95) crashes but most often it does the 'test' okay but dies in the 'burn' phase. I've tried making CD-ROM (ISO) (without an image) and then I tried using the XVCD .nrg file from this site. Neither worked. I'm attaching a copy of the message log to the bottom of this post. You can see that the problems start with a "power calibration error" at message #25.
Now, I'm wondering if there is a problem with doing the upgrade. I never had a problem with Nero 5.0. I've had NOTHING BUT problems with Nero 5.5. HOWEVER, I am also experiencing some hardware problems. I've lost one hard drive and I'm worried I may lose the other. That's actually my motivation for trying to burn a CD-ROM of my files -- I'm afraid my main disk will crash soon. My CD-writer can still READ disks okay but I'm wondering if it might be damaged as well. I'm asking for help in figuring out whether my inability to burn a disk is due to Nero 5.5 or a hardware problem.
One idea I had was to remove Nero 5.5 and reinstall 5.0. I've sent an email to ahead.de asking them for my registration code. Since they haven't responded, I went in the registry and looked up the number written there. Do you think this 6x4 (6 sets of 4 digits) code is good for both v5.0 and v5.5? I'd hate to remove Nero, try to reinstall it only to find out the code I wrote down from the reigstry doesn't work for Nero 5.0!
Thanks for any help,
-Guy Mann Dude
CD-Image
15.7.2001
12:29:23 PM #1 Text 0 File Reader.cpp, Line 133
Reader running
12:29:23 PM #2 Text 0 File Writer.cpp, Line 125
Writer PCRW404 running
12:29:23 PM #3 IMAGEGEN -10 File ImageGen.cpp, Line 354
Image was written as TAO.
12:29:23 PM #4 Text 0 File ThreadedTransferInterface.cpp, Line 665
Setup items (original item values)
0: TRM_DATA_MODE2_2336 (ISO9660 Mode2/XA)
2 indices, index0 (150) not provided
original CD pos #0 + 1101 (1101) = #1101/0:14.51
not relocatable, CD pos for caching/writing not required/not required, no patch infos
1: TRM_DATA_MODE2_2336 (CD-ROM Mode2/XA)
original CD pos #1101 + 4553 (4553) = #5654/1:15.29
relocatable, CD pos for caching/writing not required/not required, patch infos
12:30:09 PM #5 Text 0 File Burncd.cpp, Line 1509
Recorder: PHILIPS PCRW404;
CDR code: 00 97 24 01; OSJ entry from: Taiyo Yuden Company Limited
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 18 01 (LI 97:24.01), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
12:30:09 PM #6 Text 0 File ThreadedTransferInterface.cpp, Line 800
Prepare recorder PCRW404 for write in TAO
DAO infos:
MCN:
TOCTYPE: 0x20 Close CD
Tracks 1 to 2:
TRM_DATA_MODE2_2332, 2332/0x0, ISRC "", FilePos 0 349800 2917332
TRM_DATA_MODE2_2332, 2332/0x0, ISRC "", FilePos 2917332 3267132 13884728
12:30:09 PM #7 Text 0 File ThreadedTransferInterface.cpp, Line 828
Removed 2 run-out blocks from end of track 1.
12:30:09 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 828
Removed 2 run-out blocks from end of track 2.
12:30:09 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 665
Setup items (after recorder preparation)
-> TRM_DATA_MODE2_2332, 2332, config 0, wanted index0 0 blocks, length 1099 blocks [PCRW404 ]
-> TRM_DATA_MODE2_2332, 2332, config 0, wanted index0 0 blocks, length 4551 blocks [PCRW404 ]
12:30:09 PM #10 Phase 28 File dlgbrnst.cpp, Line 1353
Speed measurement started
12:30:09 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1836
Verifying CD position of item 0 (not relocatable, no CD pos, no patch infos, orig at #0): write at #0
12:30:10 PM #12 Text 0 File ThreadedTransfer.cpp, Line 218
all writers idle, stopping conversion
12:30:10 PM #13 Text 0 File ThreadedTransferInterface.cpp, Line 1836
Verifying CD position of item 1 (relocatable, no CD pos, patch infos, orig at #1101): write at #0
12:30:14 PM #14 Text 0 File ThreadedTransfer.cpp, Line 218
12:30:14 PM #15 Phase 29 File dlgbrnst.cpp, Line 1353
Speed measurement completed: 55x (8308 KB/s)
12:30:14 PM #16 Phase 32 File dlgbrnst.cpp, Line 1353
Simulation started at 4x (600 KB/s)
12:30:14 PM #17 Text 0 File ThreadedTransferInterface.cpp, Line 1836
12:30:20 PM #18 Text 0 File ThreadedTransfer.cpp, Line 218
12:30:25 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 1836
Verifying CD position of item 1 (relocatable, no CD pos, patch infos, orig at #1101): write at #1251
12:30:43 PM #20 Text 0 File ThreadedTransfer.cpp, Line 218
12:30:51 PM #21 Phase 33 File dlgbrnst.cpp, Line 1353
Simulation completed successfully at 4x (600 KB/s)
12:30:51 PM #22 Phase 36 File dlgbrnst.cpp, Line 1353
Burn process started at 4x (600 KB/s)
12:30:51 PM #23 Text 0 File ThreadedTransferInterface.cpp, Line 1836
12:31:31 PM #24 SCSI -1106 File Cdrdrv.cpp, Line 1353
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0310F184
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0xF2 0x00 0x00 0x1A 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x13
0x00 0x00 0x00 0x00 0x73 0x03
12:31:31 PM #25 mmc -1106 File Writer.cpp, Line 311
Power calibration error
12:31:31 PM #26 Text 0 File ThreadedTransfer.cpp, Line 218
12:31:31 PM #27 CDR -201 File WriterStatus.cpp, Line 162
Invalid writestate
12:31:31 PM #28 TRANSFER -18 File WriterStatus.cpp, Line 162
Could not perform EndTrack
12:31:31 PM #29 Phase 38 File dlgbrnst.cpp, Line 1353
Burn process failed at 4x (600 KB/s)
12:31:31 PM #30 Text 0 File Scsicmd.cpp, Line 371
SCSI not using temporary buffers
20 out of 20 temporary buffers allocated
Existing drivers:
File 'IoSubSys\SCSI1HLP.VXD': Ver=4.00.1111, size=19182 bytes, created 8/24/96 11:11:10 AM
File 'IoSubsys\NEROCD95.VXD': Ver=4, 0, 0, 16, size=33451 bytes, created 7/7/01 2:38:48 PM
File 'IoSubsys\C2REC.VXD': Ver=3.00.044, size=28335 bytes, created 1/6/99 6:44:36 PM
File 'IoSubsys\C2APIX.VXD': Ver=Version 1.01.026, size=10469 bytes, created 11/16/98 2:45:44 PM
File 'IoSubsys\CDFS.VXD': Ver=4.00.1111, size=59129 bytes, created 8/24/96 11:11:10 AM
File 'IoSubsys\ESDI_506.PDR': Ver=4.00.1111, size=24390 bytes, created 8/24/96 11:11:10 AM
File '..\System\Vmm32\Ios.vxd': Ver=4.00.1111, size=68938 bytes, created 8/24/96 11:11:10 AM
File 'IoSubsys\Disktsd.vxd': Ver=4.00.1111, size=18785 bytes, created 8/24/96 11:11:10 AM
Hmm? I use Nero 5.5.2.4 without any problems, I can even make VCDs with menus
I've used it under win98 and winME. So I think it might be something with your setup.
However, a LOT of people have report various problems with 5.5.2.4 and have gone back to using 5.5.2.3 (mostly menu problems). Not sure if this helps any...
Is GSpot buggy?
By terrypin in forum Newbie / General discussionsReplies: 6Last Post: 6th Oct 2011, 16:13 -
Xmedia Recode 2.2.6.3 still buggy
By pepegot1 in forum Video ConversionReplies: 2Last Post: 27th Aug 2010, 09:34 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
Buggy chapter transitions with PgcEdit Play All scheme
By ajrecs in forum Authoring (DVD)Replies: 2Last Post: 11th Oct 2008, 07:00 -
a burn size anomaly - is ImgBurn 2.4.0.0 buggy?
By JohnnyBob in forum DVD RippingReplies: 4Last Post: 21st Feb 2008, 00:45
