I have a 3 hour mpg1 file. Looking for the Easiest way to cut it up into smaller files of varying length of my choice. Any suggestions?
As usual,
Thanks All!
womble mpegVCR or virtualdubmod. VDM will require you reencode to a different format. Womble is your best bet for simple edits. If you have tmpgenc you may be able to use mpeg tools to do it.
Read my blog here.
Cuttermaran (free).
Easier to use than Womble.
No re-encoding/frameserving needed with virtualdubmod/mpg.Cheers, Jim
My DVDLab Guides
Need Software Recommendation
By JFolk in forum Newbie / General discussionsReplies: 0Last Post: 11th Jun 2010, 09:23 -
Software recommendation
By pcfitness in forum Authoring (DVD)Replies: 1Last Post: 2nd Nov 2008, 22:13 -
By Haopengyou in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2008, 08:28 -
Software recommendation?
By zeno in forum Authoring (DVD)Replies: 4Last Post: 28th Dec 2007, 12:48 -
By statman24 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2007, 12:50
