well i am bout to do the pi/pif error test now
but dang, FAST
btc 1016m tho
my liteon didnt wanna burn the 16x certified media at 16x, so thats why i tried my btc, may just be a firmware media code update???
there we go, let me here the harsh words on how that sucks
Results 1 to 12 of 12
Correct, redo it at 4x for more accurate results.
You should also put the media brand and media code in your thread as well as topic title so people know specifically what media you're using. -
u don't have good PIF
what kind of media u using
by the way, did u update ur firmware? -
PHILIPSC16 16x on the btc 1016im with A079 firmware, havent updated the firm on that drive yet
Not that fast. I got TY dvd+r that are 8x , but can burn at 12X and I can burn a 4.3gb w/ Roxio Toast on my MAC in 4 minutes and 31 seconds. That's fuggin fast.
Oh, on my PC,,, its a slay 5 minutes flat w/ NERO 6.
PC its in USB 2.0
MAC its in Firewire.
*New Mac user*, been PC user 4 life -
koolaidwa, that last scan you posted is still poor, especially as the PIF gets up past 20 or so. That disc is most likely a coaster, you probably will get read errors at the edge of the disc if you tried to make a copy of the disc.
I haven't heard the best things about BTC, but it could certainly just be cheap media or a poor firmware in this case. If you can wait 2 minutes or so longer, I'd try burning at 8x until you can get reliable burns at 16x, it's not worth saving a couple of minutes if the burn is going to come out crap. See how it burns at 8x on the Liteon for comparison, hopefully you keep your PIF peaks to less than half of that scan above. -
...on the other hand, think of all circular drink stains that your new coaster will prevent.
If God had intended us not to masturbate he would've made our arms shorter.
George Carlin -
YES that scan ended up being a f ing coaster
i think i narrowed it down, as i burnt another one using a differnt program and got less errors -
If you are burning DVDs, I suggest trying DVD Decrypter to burn the discs as ISO images. I've had the best burns and the fewest errors, consistently, burning with DVD Decrypter. It does a great job and of course it's free too.i think i narrowed it down, as i burnt another one using a differnt program and got less errors
can't read 16x disc
By jonij in forum Newbie / General discussionsReplies: 7Last Post: 15th Dec 2008, 03:35 -
Can a 4x burner write to a 16x disc?
By bobarnett in forum DVD & Blu-ray RecordersReplies: 10Last Post: 24th Sep 2008, 16:47 -
help, for read dvd disc with 16x
By flowerhorn in forum Newbie / General discussionsReplies: 8Last Post: 29th Jul 2008, 10:35 -
Best Buy Verbatim - 50-Pack 16x DVD-R Disc Spindle $12.99
By sknox in forum MediaReplies: 5Last Post: 16th Mar 2008, 21:46 -
How to burn a 157 mins. video on a 120 mins. dvd
By Gerald Sr. in forum Authoring (DVD)Replies: 2Last Post: 20th Jan 2008, 03:19
