fan-sub anime? i'm not sure, but aren't the subtitles on those burned into the picture? if they are, then no firmware will fix the problem.
in fansub encodes, they usually make the subtitles way to low in the picture and way too wide. then figure in the overscan, and the subtitles will be chopped on all sides.
Results 31 to 36 of 36
Yeah, thats what dealing with here. Also Sometimes the subtitles on top are cut off too.in fansub encodes, they usually make the subtitles way to low in the picture and way too wide. then figure in the overscan, and the subtitles will be chopped on all sides.
Don't know what this means.then figure in the overscan, and the subtitles will be chopped on all sides. -
Do the subs look okay with like bsplayer?
Some divx converters let you reposition subs, but I haven't tried those.
Try pushing the system menu button two times when playing, you never know what this may correct
Before doing a new FW be sure that the model number on the back of the machine is the same as the one on screen. If not, change the model nbr on screen to match. -
It's Fine on BSplayer.Originally Posted by handyguy
""Try pushing the system menu button two times when playing, you never know what this may correct
Interesting
""Some divx converters let you reposition subs, but I haven't tried those.""
Like different from VirtualDub? Seperate Program? -
None of these links seem to work any more... Anywhere i can get them now? I have a DVP642/37.
Most of the firmware is gone. I've also read that the new "version/model" of the 642, cannot be flashed.
Google is your Friend
Philips DVP-642 16:9 Display
By wulf109 in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Jan 2010, 12:39 -
Philips dvp 642 help?
By imemine in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Feb 2009, 02:22 -
DVD 3 Hour recording questions. Tried searching with no firm results
By redraif in forum DVD & Blu-ray RecordersReplies: 15Last Post: 22nd Jul 2007, 05:24 -
Philips DVP-642 and x.264 HD encoding
By dfishman923 in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2007, 14:36
