Im using tmpge to convert some beavis n butthead found on morpheus, they are all in .avi format. the problem i am having is when i choose the video file i want it doesnt have any sound file and when i choose the sound file manually it says its unsupported. ive alsoused virtudub but it wont work either saying the file dont have the right codec. i'm sure i have the right one, maybe not though? i dont know if i installed it wrong or what. whenever i use tmpge to convert all other .avi files it works fine. any suggestions?
download the kristal studio pack located in the toolz department. this should help you.
pc crashes when using tmpge 4.0
By ANTS17 in forum Video ConversionReplies: 1Last Post: 11th Oct 2010, 23:55 -
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 10th Apr 2009, 00:56 -
.avs scripts in TMPGE Xpress?
By ecc in forum Video ConversionReplies: 0Last Post: 12th Aug 2008, 08:39 -
TMPGe and BD template the right settings for pal -getting juttering effect
By millzy in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Jul 2008, 11:13
