I've got a 2 CD SVCD movie, which was encoded at the wrong size - it's full screen when the original film was 1.78:1.
So I'm using VirtualDub (MPG Version) to frameserve it to TMPGEnc with a resize filter (about 480x355 instead of 480x480).
So far so good. But, a major problem! I want to put these on CD afterwards, obviously.
The original files are 100% of a 700 Meg CD (about 778 Meg). Since I'm frameserving to TMPGEnc, I can't use the Wizard, which means I can't use the bitrate calculator in the wizard to work out the average bitrate to make it 100% of a 700 Meg CD again. If I leave it as 2520 Kbits per sec (default for SVCD), it makes each half about 1.3 gigs.
I know that sometimes TMPGEnc can be tricked into opening the Wizard on SVCDs to get to the calculator stage and then cancelling - by installing PowerDVD. I've done this before and had it working before. But for some reason when I try this with these files, TMGEnc crashes out.
How can I figure out the bitrate to give TMPGEnc ? Or even better, how can I invoke the bitrate calculator without using the wizard? I 've had a swizz through the site here about bitrate calculators and am completely lost. Help!!
Closed Thread
Cant you use a bit rate calculator ? I think there is a link to one in the site here.
Here ya go i think
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
https://www.videohelp.com/calc.htm (see your other post).
Cheers, Jim
My DVDLab Guides
DVD to HD (resize and enhance image quality)
By SB4 in forum RestorationReplies: 12Last Post: 14th Dec 2010, 16:54 -
Entering Video Bitrate Makes Preset Switch To SVCD
By akulier in forum ffmpegX general discussionReplies: 7Last Post: 26th Feb 2008, 05:12 -
By akulier in forum ffmpegX general discussionReplies: 1Last Post: 21st Feb 2008, 04:31 -
Which one directshow filter to resize the image ?
By jazzzy in forum Software PlayingReplies: 1Last Post: 20th Feb 2008, 09:55 -
Auto resize Image in Avisynth
By GioBarque in forum Newbie / General discussionsReplies: 8Last Post: 21st Jul 2007, 12:02
