I was just wondering if there was a significant difference between the original Audigy and those super expensive Audigy 2 ZS (or whatever)? I might be able to find an original 5.1 Audigy Gamer edition for cheap, which is the basis for this question. Thanks.
Results 1 to 11 of 11
Your base? Well, they belong to me now...
Well for one the ZS will play DVD audio and I'm not referring to the kind found on DVD's if that makes any sense.
Audigy = 5.1
Audigy 2 = 6.1
Audigy 2 ZS = 7.1
The Audigy 2 will play DVD-Audio as well.Nothing can stop me now, 'cause I don't care anymore. -
Don't the ZS versions have later versions of EAX hardware on them as well? I'd only get the one with the breakout box though, I love those things
FB-DIMM are the real cause of global warming -
EAX, DTS & THX, I got the plane Jane one but I think they are all the same except for the accessories.
Edit: THX certified..... Guess it's an award
The Audigy 2 (non ZS) has EAX DTS (-ES I believe) and THX.
Highly aware of DVD Audio (and the fact that it is a format that doesn't seem to be catching on). I think I'm just gonna go with a regular Audigy for now since I don't have enough room for 7 freakin' speakers in my PC area. Thanks for the input!Originally Posted by thecoalmanYour base? Well, they belong to me now...
Yes, the masses are more than happy with CD quality or even MP3Originally Posted by studtrooper
Either that or they are like me and just tired of the same old crap that the bands are putting out these days - so why would I want to have even MORE of that crap on my player??
(DVD audio can hold more music - at a higher bitrate too...) -
There's a lot out there on DVD-Audio that's good, the only problem is that it usually doesn't come out until AFTER the CD is released. Unless you're just dying to hear in in 5.1, it's not worth buying it twice. I'd probably buy more if the release dates were the same. I have a Dual-Disc (CD/DVD-Audio) of The Downward Spiral and I can definitely hear the difference between the two sides. DVD-Audio won't survive if their marketing is as lackluster as it has been, which would be a shame.
With the Audigy (1) you can also use Live Drive I or Live Drive IR. These older models are not compatible with the following Audigy cards and sometimes you can buy them very cheap on-line.
WDTV Live to Soundblaster Audigy 2?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 3Last Post: 11th Dec 2010, 23:25 -
Creative SB Soundblaster Live and Ubuntu 8.04
By Ogilvy in forum LinuxReplies: 6Last Post: 12th Jul 2010, 07:50 -
Audigy Soundblaster SE Installation Problems!!!
By lapetite_66 in forum AudioReplies: 1Last Post: 2nd May 2009, 21:45 -
No soundblaster midi with x-fi extreme audio pci-e
By johns0 in forum ComputerReplies: 0Last Post: 11th Jan 2008, 20:01 -
Audigy Vista Alchemy fiasco...
By ofbarea in forum ComputerReplies: 1Last Post: 3rd Jul 2007, 08:51
