Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Apr 2004
    In a NY zone
    I hope this helps for others so here it goes.
    I got 25 Piodata dvds (8x printable) from Meritline and the first 5 were good. So I made the rest but not all at once and they were all the same video for a dance recital. Enter problems, all 20 after either wouldn't play or looked like I threw the video camcorder across the room-yeah that bad!
    I then used (and should have from the start) TDK dvds and all was good after that So just a caution as I didn't do any repairs or shut downs to my iBook just found it was bad media. I'm waiting on a response from Meritline as to whether anyone else had complaints on that media.
  2. Member terryj's Avatar
    N3525.24068, W09734.204
    You could have saved yourself some headache if you would
    just use google and search:
    https://www.videohelp.com/dvdmedia.php?selectmedia=376#comments
    https://www.videohelp.com/forum/viewtopic.php?t=247730&highlight=piodata
    http://www.digitalfaq.com/media/dvdmedia.htm
    the only blessing: Meritline will take the media back,
    but you have to phone call and b!tch slap them some,
    but they will give you your money back.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Apr 2004
    In a NY zone
    Yes terryj, boy could I and man I should have! My fault
    As far as your way of getting money back hell yeah! But still my fault for not doing a complete search first. Guess that happens when one is tired and does a half assed search
