Using the plextor m402u , I can capture at high quality or low quaility (for longer running tapes ) when transferring from VHS.
Is it better to capture at the high quality (full D1) and then use something like Tmpg Express to convert to 320 x240 or should I just use that lower setting when recording ?
I thought someone had said that it is better to capture at the highest possible and then encode down, rather than encoding on the fly...or do you think Ill see a difference at all..anybody else have results?
thanx,zep
You are like to receive varrying opinions on this, so do what looks and sounds best to you.
As far as I am concerned, the "best" method involves no re-encoding at all. Re-encoding is time consuming and can result in lower quality. If you discover your file is a bit too big (15% or less) it's okay to re-encode. Any more than that, then re-capture at the correct settings.
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
What software will capture MPEG-1 ?
By Palmer Eldritch in forum Capturing and VCRReplies: 17Last Post: 4th Jan 2010, 18:12 -
MPEG 2 Capture
By MI6 in forum Capturing and VCRReplies: 1Last Post: 29th Apr 2008, 19:02 -
MPEG-2 capture inconsistency
By danknugz in forum Capturing and VCRReplies: 18Last Post: 16th Nov 2007, 11:00 -
How do I capture a still picture from mpeg?
By illyad in forum Capturing and VCRReplies: 4Last Post: 15th Jun 2007, 20:30
