I have been doing DVDs for some time now but there has always been one thing that I did not seam to find any info on. How to do a DVD that will install a player if the disc was put into a computer?
The perfect scenario would be that it did not install itself on the hard drive but still could play the DVD-video, maybe install itself onto a RAMdiisc and run from there.
So does this dream software exist? and if so, where can I find it?
Something similar hs been discussed here a couple of times. Check out the following links, and see if they give you any help.
https://www.videohelp.com/forum/viewtopic.php?t=229910&highlight=autorun
https://www.videohelp.com/forum/viewtopic.php?t=215571&highlight=autorun -
The closest thing to that I have seen is in Ulead DVD Workshop which gives you the option of including there DVD player on the disc when you author it. I've never tried it so have no idea how well it works. I would assume it would require you ti install it on the system.
WinXP SP3 Problems Installing Media Player 11
By bevills1 in forum ComputerReplies: 0Last Post: 31st May 2011, 12:00 -
Media Player Classic: Auto Zoom: Auto Fit logic
By DRP in forum Software PlayingReplies: 0Last Post: 29th Apr 2010, 09:59 -
Mozilla Seamonkey Problem Installing Shockwave Flash Player
By bevills1 in forum ComputerReplies: 2Last Post: 2nd Jul 2009, 12:47 -
Authoring an auto play DVD or editing an exsisting ONE to auto play
By theewizard in forum Authoring (DVD)Replies: 22Last Post: 16th Mar 2008, 12:06 -
problems installing flash player
By stretchweider in forum MacReplies: 3Last Post: 29th Aug 2007, 10:51
