General Information
Drive: LITE-ON DVD SOHD-167T
Firmware: 9S19
Disc: DVD+R (RICOHJPN R01)
Selected speed: Maximum
PI errors
Maximum: 57
Average: 29.40
Total: 264630
PI failures
Maximum: 26
Average: 1.21
Total: 52684
PO failures: n/a
Jitter: n/a
Scanning statistics
Number of samples: 77307
Average scanning interval: 1.16 ECC
Glitches removed: 0
should i be worried about all those errors on my disc's?? the dvd was burned at 4x..if it matters.
and the disc got a quality rating of 17 points is that good or bad??
That's not bad but Lite-On DVD-ROM's are notorious for wrong error reporting,use a DVD writer.
DVD-ROMs are not the best choice for doing these tests, but they usually suffice. One thing you should do when you run these tests, run them at 4x instead of maximum, 4x is more or less the standard and will give you much more accurate results typically.
Here's an in depth description of how to interpret PI/PO tests like yours:
http://club.cdfreaks.com/showthread.php?t=80545 -
I use the same drive to test mine.
If you follow steve's suggestion to reduce the test speed, you will notice a dramatic improvement. I also suspect your max pif will not be 26 anymore, therefore your score will be better.
Do not pay too much attention to the final score, if you have one pif spike of 30 (I'm not sure the exact number), you have 0.
What's important is high pif area. This may indicate potential playback issues.
I would not worried about this test.
Nero CD/DVD Speed (4.7.7.5) -Error
By bluemoss in forum DVD & Blu-ray WritersReplies: 14Last Post: 12th Jan 2012, 00:08 -
I keep getting write errors in Nero - help :(
By Akhet in forum ComputerReplies: 11Last Post: 30th Oct 2009, 14:51 -
Nero 6 vs Xp updates Mid July 2009 , NO DISC DETECTED
By org74 in forum DVD RippingReplies: 0Last Post: 1st Aug 2009, 14:35 -
burning errors in nero & tmgenc dvd3
By brushuk in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2008, 12:23 -
DVD Shrink/Nero burn errors
By chibimaru in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jun 2007, 04:22
