I have movie (2500 kbps) and movie segment (8500 kbps) in my project. Can this difference in a bitrate be a problem and aborts compilition process?
Results 1 to 13 of 13
What program(s)?
What framerates?
What aspect ratios?Cheers, Jim
My DVDLab Guides -
The program is dvdlab-pro. Movie and movie segment are NTSC 720x480, 29.97 fps, 4:3.
Nope, that's not the problem.
Do you have any motion menus?
If so, redo them and save as avi, not mpg.
Encode them separately, then import.
If not, something in your structure is not producing a compliant dvd. Empty VTS, menu links invalid, something...Cheers, Jim
My DVDLab Guides -
No, I don't have motion menus. I don't have empty vts, and broken links. I double checked them. Once I had such problem when I had 16:9 and 4:3 in one vhs, but now everything seems the same to me... Thank you for the ideas I will check menu structure again...
I guess that's possible. I never exceed 9000kbps including audio.
Save your project, and try with a re-encoded version of your mpeg, using a lower bitrate.
See if that makes a difference (it shouldn't).
The other option is to use AC3 audio (if you aren't already) as dvdlab has been known to crash on PCM.Cheers, Jim
My DVDLab Guides -
I'll try to reincode my mpeg, but I also don't believe in success. I use ac3 in every my project because it gives me resonable quality with reasonable project size. I don't like to shrink it after compilation.
Yes, I reencoded my video with lower bitrate. The result is the same - nothing new. However, now I can see that process aborted when placing navigation parameters. Can it be the switched menu with links to another menu?
Shouldn't be. I use switched motion menus, never had a problem. Can you post a screenshot of your connections tab, and assets tab?
Cheers, Jim
My DVDLab Guides -
Thank you for reply. I found the problem. I don't know how, but ac3 files that I converted with tmpgenc plug-in corrupted the process. As soon as I replaced them with wav, everything is OK.
I don't know why, ac3 plug-in doesn't work well because in previous project I use it and everything was just fine. But I notice that plugin freezes trying to convert some files. Maybe the problem is in the headers of audio. I don't know. -
Cheers, Jim
My DVDLab Guides
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 09:26 -
Joint 2 parts of movie, but after ifo files created: ERRORS at playback
By johnnyemh in forum EditingReplies: 1Last Post: 31st Dec 2008, 17:25 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 08:31 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 14:07 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
