Results 1 to 11 of 11
  1. Member ticos2000's Avatar
    May 2001
    bogota colombia southamer
    I have captured home movies on mpeg2 format and then i built a dvd with this files.
    My question is regarding the vob files that now you have created and that later on probably you will need to edit again. Since I do not keep the mpeg2 files I captured , how can i go back to mpeg2 files based on my vob files ?
    Of course i am thinking in not reencoding issues, so, is there anyway to go back to my mpeg 2 files?
    thanks in advance
    Best regards from colombia south america
    ticos2000
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    vob files are mpeg2 files , just use dvd decryptor and stream mode ...
  3. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Or try renaming the extension ".MPG".
    Or you could just open the VOBs in an editor and export to MPG.
    Or you could demux with Vobrator and open the elemental streams in an editor, then save as MPG. Pick one that works
  4. Member ticos2000's Avatar
    May 2001
    thanks a lot. i will try and lñet you know
    regards
    hector
  5. Member ticos2000's Avatar
    May 2001
    Originally Posted by Baldrick
    https://www.videohelp.com/guides.php?guideid=638&howtoselect=3;6#638
    Thanks a lot baldrick. That guide is great . helped me solving my question
    keep the hard work
    best regards from colombia south america
    hector
  6. Hi ticos2000,
    If your VOB files are stored in DVD file structure i.e. in VIDOE_TS & AUDIO_TS folders then probably you have more than one vob files. Then you can uses "Nero Vision Express" or "WinAVI Video Convetrer" or "Super DVD Ripper" to reconvert your VOB files to mpeg files. If you have just one vob file you can use TMPGEnc to convert into mpeg file. Depending on the version of TMPGEnc you use, you MAY have trouble with the audio encoding. TMPGEnc does not read AC3 encoded VOB files.
  7. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    VOBs don't have to (and shouldn't) be reencoded to get mpegs. Just demuxed.
    /Mats
  8. Member ticos2000's Avatar
    May 2001
    Originally Posted by sanjayk
    Hi ticos2000,
    thanks for you sugestions, actually i followed baldrick recomendation and definitely you do not need to reencode to mpeg2 files, i tried tmpeg dvd author and that made the trickl .....VOB back to mpeg2 flawlessly!!!
    thanks again for your answers
  9. Knows a few things Stiiv's Avatar
    Aug 2004
    Fallentown, PA
    Don'tcha get a warm, fuzzy feeling after a series of posts like that? Newbie needs info, newbie gets info, everybody happy. I love this place.
    Stiiv
