I went to remove the "Mainconcept DV codec" and was unable to remove it using ADD/REMOVE Programs. I then tried to install the newer version, as given by this site, and got an error message. WOW! I cannot install the new codec and possibly other Windows Installer software-real trouble.
I search the WEB and found this site:
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
It contains a Windows Installer CleanUp Utility. I download it and ran it, and away went my problems. It lists all programs that use the W.I. and allows you to remove the entire contents from the Registry. After removing the old Mainconcept codec, using the utility, I was able to install the new one without issue.
A good utility to have. It works for all versions of Windows 32 bit systems including Win 98.
Results 1 to 1 of 1
What is windows installer for?
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 7th Jan 2010, 13:51 -
Do you know about the Windows Installer Clean Up Utility?
By ahhaa in forum ComputerReplies: 3Last Post: 17th Feb 2009, 13:37 -
windows installer?
By marcusden69 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 15th Feb 2009, 07:36 -
Windows Installer problem
By visjds1 in forum ComputerReplies: 3Last Post: 2nd Oct 2008, 13:03 -
By visjds1 in forum ComputerReplies: 6Last Post: 20th Aug 2008, 13:35
