    Dec 2003
    Spain
    It's the ac3 audio of a dvd movie I bought. The film is old, from the forties, but that doesn't justifies doing a bad job with the sound.
    It reminds me of some wrong results I had sometimes when trying to get rid of videotapes hiss with Cool Edit pro. If I take out too much I obtained that metal echo, as if the actors where speaking through a tin. Then I could correct it going back to the original sound and taking out less hiss, but in this case is the original sound (the ac3 from my movie) that already has that disgusting effect now and then.
    Is there some way of getting rid of it? May be with Adobe Audition and some VST plugin? Or I'd better forget it?
    Thanks in advance.
  2. Member Soopafresh's Avatar
    Jan 2004
    Believe it or not, it might sound more natural if you added some hiss to it. Just a thought.
    Dec 2003
    Spain
    Thanks for answering.
    How could I add that hiss? Some option in Cool Edit?
    Is that something that you've done some time?
  4. Member Soopafresh's Avatar
    Jan 2004
    Cool Edit allows You to do multitracking, right ?
    Find a hiss source and add it to the audio.
    Yes, I did it to an overly noise reduced audio recording and it made it sound less artificial. Your mileage may vary....
  5. Mod Neophyte redwudz's Avatar
    USA
    I had the same problem with metalic sounding audio a while back. I'll have to try the 'hiss' idea. I have been trying Audacity to filter some short AVIs with some luck. I see it has a 'White noise' generator that might supply a 'hiss'.
    Thanks for the suggestion, Soopafresh. I figure whatever I do couldn't make it any worse.
