A little bird told me when making a backup of your DVDs with say DVDBackup or MTR that a copy(fingerprint) is engrained on the copied DVD. Is this actually true or is it nonsense ?
Results 1 to 10 of 10
ROFLMAO!!! Oh man, best tip EVAR. I think this rumor got started because DVDXCopy does something similar on the PC... Either that, or because MTR leaves behind traces of the DVDs you've backed up on your HD due to libdvdcss (there will be an option to remove those in 2.7).
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
What is the name of that invisible file? I can't find that thread from a while ago.Originally Posted by WiseWeasel
TIA
MD -
There is a utility program around called KillTheRipper. I personally don't use it but it should do the job.
http://www.versiontracker.com/dyn/moreinfo/macosx/24766
Cheers,
JoachimS -
The folder is called .dvdcss, and is located in the user's home directory. It's invisible, as the name starts with a period.
In the finder you can Use the Go>Go To Folder menu command and type in /users/yourusername/.dvdcss and it will open up the folder for you (where yourusername is your user name) You can then trash the folders found inside. Not sure why you should bother, but privacy freaks might want to school me.
This Kill The Ripper, WTF... does it work?? Is it safe? Do you use the regular MTR and then KTR? lol
*New Mac user*, been PC user 4 life -
pixeljammedia: Or, open Terminal and type (carefully): rm -rf ~/.dvdcss, as you probably know. I agree with you -- why bother? Surely there are more interesting files on a security-compromised system, especially if it belongs to a criminal.
Regal: Find out more about KillTheRipper on the VersionTracker product page (via JoachimS's link), MacUpdate, et.al. -
MTR 2.7 will also have an option in the prefs to delete that folder upon quitting.
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 04:35 -
Choosing a DVD player for backups
By akersaz in forum DVD RippingReplies: 8Last Post: 11th Jul 2008, 10:46 -
Tool to Rip a DVD on MAC for backups?
By fiiido in forum MacReplies: 6Last Post: 22nd May 2008, 07:29 -
Looking for best way to compress dvd backups
By Wolfsrudel in forum Video ConversionReplies: 8Last Post: 2nd Jan 2008, 13:36 -
DVD and Photo backups
By didikai in forum Newbie / General discussionsReplies: 6Last Post: 14th Jun 2007, 00:26
