  1. For reasons unknown my standalone dvd players will not read iso or when i copy the bup and vob files the player will not read it either. is there a way to convert these into any other format? or is there somthing i need to do to make my players work?
  2. Member Epicurus8a's Avatar
    Ocean West, USA (ATSC)
    VOBs (MPEG2) can be converted to other formats. However, when the converted files are re-authored, they become VOBs again.
    So, It sounds like you have an authoring problem. How are you authoring your DVDs?
  3. i dont quite know what "authoring " means please explane
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    https://www.videohelp.com/author
    AUTHORING means creating dvd compliant files. Those are the vobs, bups and ifos.
    Also - https://www.videohelp.com/convert
    There are many options to convert back to mpeg2 or some other format to start over. Of course if you have the ORIGINAL source (which you mostly SHOULD have unless its homemade ) it would be best to start over to preserve quality.
    Kevin
  5. yoda you got pm
