Originally posted by hank315
For some time I've been working on a MPEG2 encoder,
maybe there's somebody who want to run some tests with it.
Screenshot of the version 0.1 by Hank315
Some information about the encoder (named HC):
(complete manual is included)
Input can be a d2v project or input using Avisynth.
No fancy GUI, the input is controlled by a serie of (simple) commands in a control file.
The encoder should run on any Intel and AMD processor using Windows XP/2000.
At least MMX/SSE must be present to run the encoder.
If SSE2 or SSE3 is present HC will also use it.
2 pass VBR encoding.
Variable GOP structure dependent of the video content or fixed GOP structure.
Scene change detection.
Pre-programmed matrices or use your own matrices.
Restart possibility to run the second pass again.
Bitrate control: average and max bitrate can be set.
Buffer underflows will not occur, the VBV is constantly checked so no bitrate spikes.
Download Version 0.1
Please remember that it is a work in progress... there may be a few bugs.
NOTES:
Living in PAL land it is hard to get NTSC material, it should work OK but if not please let me know.
Originally posted by Amnon82
Here is my GUI. I'm working now with Hank together on this baby.
Features of the GUI:
*Very small and easy to use
*Reloads the settings of the last run
*Uses HCEnc 0.01 (Till now I don't have a newer commandline-version of HC)
Screenshots:
Download HCEnc 0.01
I hope everybody likes it more than my last build.
Results 1 to 20 of 20
That looks really nice.
The only thing I could think of to make it better would be direct ability to input AVI (raw, DV, HuffYUV, MJPEG, Divx, Xvid) or MPEG files (MPEG1, MPEG2).
I would suggest the author at least include it with some sample AVISYNTH scripts for the inexperienced ABISYNTH'ers. Hopefully some good ones, really simple, no filters.Want my help? Ask here! (not via PM!)
looks great - nice GUI
As I can tell so far:
The final gui will almost look like the one I did.
My gui is only a "timebridge" till hank releases a version
with his gui.
Normaly he won't code a gui, but I pushed him to it.
... he hated guis. Now he started to code it and understood how many fun it is to do it.
Also he speeded the core up. Till now I encode with profile good in the firstpass with ca. 20 FPS and 60 FPS with my AMD 64 3.500+.
In the next version is the same speed with the highest qualitysettings.
Also I plan to do a quality test with HC 0.01, CCE 2.70 SP and QuEnc.
I will take scenes of Matrix 3 to do it.
So stay tuned for the next newsupdate.
The original thread of HC will be found here -
How are there free mpeg-2 encoders now? I thought a royalty was owed to someone for that?
so this one does NOT accept AVI (DV from my camcorder)? If it does I'll try it, but I don't do much other than DV.
From what I understand, these "free" encoders are getting around the fee by placing responsibility to pay it on the shoulders of the user. I could be wrong though.
Darryl -
here the promissed test:
I did a little Quality-Test with CCE 2.70 SP, QuEnc 0.59b2 and HC 0.01
You can see the results here
The Settings are:
CCE
Bitrate: Min. 0, Avg. 6000 Max. 8000
Matrix: AutoQ2
Filter: No Filter
GOP: M=3 N/M=4
V/C=30 Pass=2
Quantizer Quantization: 30
Intrablock DC: 9
Progressiv + ZigZag
Aspect: 16:9
HC
Bitrate: Avg. 6000000 Max. 8000000
Matrix: AutoQ2
CPU: SSE2 Profile: BEST
GOP: 12 2
Scene Detection: ON
VBV Check: ON
DC Pred: 9
Scanmethod: ZigZag
Aspect: 16:9
QuEnc
Bitrate: 6000 VBR Max. 8000
Matrix: AutoQ2
High Quality: ON Use Trellis: ON
GOP: 12 2
Scene Detection: ON
2 Pass Enc.: ON
DC: 9
Extrem+Slow Settings: ON
Aspect: 16:9 -
the matrix used is for very low bit rates ... but it doesnt really mater as these frames are so dark as not needing many bits anyway ... the original also dosnt look so hot oddly enough . but all 3 match it
I'm solely interested in DV to XviD.
You are in breach of the forum rules and are being issued with a formal warning.
Do not hijack topics.
Please try to stick to the author's first post in each topic,
if you want to discuss something else, create a new topic.
/ Moderator lordsmurf -
Version 0.1 just released. Forl download check the first post.
Encodertest will be found here: go to test -
If the goal was to make them all look the same, congrats.Originally Posted by Amnon82
To me, they all look about the same.
Although I agree with BJ_M, dark is not a real test.
Dark shold be one of many tests.
This is one reason I like T3 for testing.
That movie has material for pretty much every kind of test.Want my help? Ask here! (not via PM!)
The goal is to get better
Just finished my second GUI-Design. Get it from the first post. -
I'm sorry about my previous post. I was extremely tired when I viewed that thread and didn't even clue in that it was solely a MPEG-2 encoder. My sincere apologies! Can someone delete that post and this one? I love the GUI, very advanced and professional looking. I hope it supports direct DV soon so I can convert directly. Does it? If not, soon? In the process of getting a SP2-compatible FireWire card. Can't wait for more tests.
HCenc and PanScan
By Comp360 in forum Video ConversionReplies: 2Last Post: 14th Mar 2011, 17:35 -
Problem with HCenc 0.24.
By HolyFries in forum Video ConversionReplies: 2Last Post: 17th Jun 2010, 18:03 -
By HolyFries in forum Newbie / General discussionsReplies: 0Last Post: 17th Jun 2010, 13:18 -
HCenc Question
By Maikeru-sama in forum Video ConversionReplies: 6Last Post: 18th Aug 2008, 12:01 -
HCEnc
By Belfour in forum DVD RippingReplies: 1Last Post: 28th Jun 2007, 09:57
