I goofed when encoding and made a movie that's supposed to be 16:9 a 4:3. I don't know if the ratio is only in the header or what. anyway, any way I can fix it without reencoding? or even adding black bars, but I'll be watching the other post for that. thanks
I've never tried this, and it may (probably) won't work but I noticed that in the program MPEG Sequence Maker there is a pull-down menu for the display aspect ratio with selectable options. You could try demuxing your mpeg in TMPGEnc (mpeg tools menu), then open the video file (.m1v or .m2v) in MPEG Sequence Maker, select the desired aspect ratio, and select Start. As far as I know this just adds/changes header info in the stream. When its finished processing the video file, go back into TMPGEnc and re-mux your video and audio files back into a mpeg file using the appropriate VCD/SVCD template.
Edit - Did you mean you selected 4:3 as the source aspect ratio, or as the aspect ratio for the encoded mpeg? I think for VCD/SVCD you have to select 4:3 for the encoded mpeg.
If you have a 16:9 movie, you would select 16:9 for the source aspect ratio, and 4:3 for the encoded mpeg so that TMPGEnc adds the black borders. If you selected the wrong source aspect ratio I think you will have to re-encode.
<font size=-1>[ This Message was edited by: JHebert on 2001-12-06 12:49:37 ]</font>
WMV Aspect Ratio Changing?
By Crazyj32 in forum Video ConversionReplies: 11Last Post: 10th Aug 2014, 07:53 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 19:18 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 13:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 06:40 -
Changing aspect ratio on an xvid encode
By SupaDawg in forum EditingReplies: 1Last Post: 6th Jan 2008, 04:59
