I am trying to uninstall a program from my computer and keep getting this message>.I have tried through the add/remove and also with a program called regseeker to no avail.Any suggestions please.Just o add this file is not in the program folder,so i have no idea where it has gone if it was ever there.
Reinstall the original program, over top of wherever it was. Then uninstall.
Cheers, Jim
My DVDLab Guides -
Go into regedit and search for the program name that you are trying to uninstall and delete every occurrence of that name.
Make sure UNWISE and INSTALL.LOG are in the same directory. Then doubl-click UNWISE.EXE and uninstall it that way.
Unless the INSTALL.LOG file is gone. -
ok thanks people,cant rid it,tried everything.If its not one problem its another
Cannot uninstall Nero 9
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 25th Dec 2009, 08:31 -
Uninstall Office97 Problem
By bevills1 in forum ComputerReplies: 6Last Post: 26th Jun 2009, 16:39 -
Can't uninstall codecs
By boonebaker in forum Newbie / General discussionsReplies: 8Last Post: 7th Mar 2008, 16:09 -
How do you uninstall WMP 10?
By rayden54 in forum Software PlayingReplies: 5Last Post: 8th Jan 2008, 15:59 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 10:55
